So I did the IAC Mod
ORIGINAL: kenv
That looks easy. Where did ya get the plug & what size hole did you drill in it??
ORIGINAL: 8banger
Heres the same mod,,different approach...simple plug,,,drill small hole..install in rubber tube....done..
part numbers on the plug 555-015..drilled a 3/16 hole and works great...Had the idle hang before F/I and after adding F/I it was WORSE...So ...internet search..found the Copper plug mod.Found this freeze out plug a work(mechanic by trade)...and the rest is history....
My hole is 3/16ths but if I am at a stop light with my AC on my idle drops to 300, then to zero. Going to pull out the new gasket and make the hole a touch bigger. I am glad that the idle hang is gone.
I tried to find the 1/2 in freeze plug at my local parts store, but all they had was a kit for like 15 bucks. I got the gasket paper for free at my departments vehicles division so guess which way I went...
so yeah i did this mod early on today and it made me idle way higher and i dont feel like idleing at 900-1000 rpm at a stop ='[ i mean it was a "noticeable" drop in hanging RPMs but not very significant.
ORIGINAL: EaZy DuZ iT
hey guys i just did IAC MOD, my check engine light came on..is it supposed to do that?
