please answer sooonnnn!!!!
Old May 13, 2007 | 08:27 PM
22kart22's Avatar
22kart22
Default please answer sooonnnn!!!!
Hi guys. My brother has a 2000 gt, and is replacing pads and rotors. The rotors are on, but he cant compress the cylinder enough to fit them over the pads. The rotors and pads are spec. size.
We used clamps and could not get them to retain their position?
What do we doooo???
thanks all!
Old May 13, 2007 | 08:30 PM
MUSTANGRIDAH4LIFE's Avatar
MUSTANGRIDAH4LIFE
Default RE: please answer sooonnnn!!!!
Did the pistons lock up or did the go in then just stop?
22kart22's Avatar
22kart22
no they cannot compress at all.
Old May 13, 2007 | 08:34 PM
03DSG's Avatar
03DSG
[align=left]is the top to the master cylinder off? are you using a c-clamp?
[/align]
arcticman37's Avatar
arcticman37
The front I used a c clamp on mine but the rear you need a tool to spin the piston while you push it. They have them at any auto store.
dtkikols's Avatar
dtkikols
..i tried turning the piston clockwise like the haynes manual says but it wont move in at all. and the C clamp wont compress it either. this is the rear calipers if we didnt mention it. fronts compressed like butter.
thanks!
MUSTANGRIDAH4LIFE
did you use the old pad in between the clamp and piston,you do this to apply an even force.
Old May 13, 2007 | 08:35 PM
Fizzics Boy's Avatar
Fizzics Boy
The front pistons should just compress using a C clamp. The rear ones need to be screwed back in. They have a tool at autozone for 10 bucks. You can also be cheap like me a use a pair of needle nose pliers to do it. Also take the cap off of the brake fluid resevoir, as compressing the pistons back in will cause the level to rise.
Old May 13, 2007 | 08:36 PM
dtkikols's Avatar
dtkikols
thanks guys i guess ill try the tool from i guess autozone tomorrow and see if it works
Old May 13, 2007 | 08:38 PM
MUSTANGRIDAH4LIFE
OMG in that case u need the special brake compessor tool for the rears cuz they have to be turned in you can not do without this tool good news is its a free rental tool at any murrys autozone,etc.
