Thermostat help.......
Old May 20, 2007 | 05:45 PM
dmrush26's Avatar
dmrush26
Default Thermostat help.......
Well i flushed my radiator this past weekend. Everything was fine until my little radiator light came on. I took the car in and had the coolant system pressurized and it wouldn't even hold 6 psi. I believe it is supposed to hold 16 psi. Well we found the leak, it was right where the thermostat is. When you undo the two bolts then take the thermostat out there is an o-ring. I replaced that o-ring with a new one. We put it back together and low and behold it still leaks. We took it apart again, cleaned everything up, and put it back together. Still leaked. Took it apart again and put two o-rings in there, one under the thermostat and one on top of the thermostat and it seemed to fix the problem. Pressurized the system and everything looked good. Took the car out this morning to get some things. When i got home i could smell the "sweet" smell of coolant. IT'S LEAKING AGAIN!!! Don't know what else to do. Need some help.
Old May 20, 2007 | 06:12 PM
svt_97cobra's Avatar
svt_97cobra
I ♥ Acer
Default RE: Thermostat help.......
Do you have a thermostat gasket
Old May 20, 2007 | 06:15 PM
99gtstang's Avatar
99gtstang
ORIGINAL: dmrush26
i just flushed mine and if i am not mistaken the rings goes on top of the thermostat between the housing you bolt on try taking the bottom one off
try that
Old May 20, 2007 | 06:18 PM
racing96gt's Avatar
racing96gt
couldit be anything else cause mine was the same way and it was leaking and i couldnt figure out where it was coming from. i could smell it but couldnt see it and finally one day i got home and went to check it and it was pooring like a water fall. turns out that there was a hole in my radiator.
Old May 20, 2007 | 09:43 PM
dmrush26's Avatar
dmrush26
No i don't have a thermostat gasket. I think i might go to the autoparts store and buy some gasket material and make my own gasket. The car hasn't ran hot or anything. But it just aggravates me when i know something's wrong with my car and it would seem to be a simple fix but it's not.
Old May 20, 2007 | 09:46 PM
Matts00GT's Avatar
Matts00GT
Have you tried silicone?
Old May 20, 2007 | 09:50 PM
svt_97cobra
I ♥ Acer
Buy a Good New thermostat, A Goodthermostat should come with a one side sticky gasket and put some high temp silicone on it and that should keep it from leakin
Old May 20, 2007 | 09:54 PM
8banger's Avatar
8banger
Do you have the PLASTIC crossover tube (under the t-stat housing) (is it plastic?)Mine was cracked,,replaced with an updated aluminum crossover ford version intake manifold....
Old May 20, 2007 | 09:55 PM
8banger's Avatar
8banger
I see you have a 99 35th also.....minehad the plastic crossover .....
Old May 21, 2007 | 11:24 AM
dmrush26's Avatar
dmrush26
8banger how much was the aluminum crossover? Do need to replace the whole intake manifold? I hope not.
