GOt 2 problems
Old May 22, 2007 | 01:13 AM
BADSEED's Avatar
BADSEED
Default GOt 2 problems
i have 2 problems
1) i have some stupid yellow light that wont shut off it looks like a trash barrel with an X through it...and how u shut it off?
2) and reverse lights dont work on my car either how do i fix that?
thanks
Old May 22, 2007 | 01:15 AM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: GOt 2 problems
The light is the radiator light
Old May 22, 2007 | 01:17 AM
BADSEED's Avatar
BADSEED
ORIGINAL: code3GT
how do i get rid of its been on since june 1 when i bought it and its pissing me off
Old May 22, 2007 | 01:18 AM
fiad06's Avatar
fiad06
it hought the barell with the x is the coolant...and change ur reverse light bulbs?
shadowfoxx's Avatar
shadowfoxx
ORIGINAL: BADSEED
i have 2 problems
thanks
like code said .. problem #1 is the radiator light.. I had it come on once for no reason.. I checked the fluid levels and everything was fine.. I unplugged the battery cable and plugged it back in and it never came back on after that.. not saying that will work for you but it's worth a shot.
Old May 22, 2007 | 01:30 AM
BADSEED's Avatar
BADSEED
ORIGINAL: shadowfoxx
ORIGINAL: BADSEED
i have 2 problems
thanks
did that already mothing has been on like i siad since i bought it since june1
Old May 22, 2007 | 01:32 AM
yourmom6990's Avatar
yourmom6990
umm. change your reverse lights. their probably burnt out.
check coolant level, and make sure the coolant sensor and everything isnt dirty or anything.
Old May 22, 2007 | 03:38 AM
red96gtconvtbl's Avatar
red96gtconvtbl
My low coolant light seems to act up in the winter, but not in the summer. When it's cold, it'll stay on for 10 minutes or so until the car warms up, then I'm fine. In the winter I never see it at all. Just make sure your fluid level is ok and you'll be fine.
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
