10 psi ?
Old May 22, 2007 | 03:19 PM
White02GT's Avatar
White02GT
Default 10 psi ?
Is 10 pounds of boost on a stock 02 gt mustang with a auto is it gonna hurt it bad. Like for a procharger
Old May 22, 2007 | 03:21 PM
svt_97cobra's Avatar
svt_97cobra
I ♥ Acer
Default RE: 10 psi ?
Be sure to geta Good Tune, and dont run it lean, I would say it would be alright.
Old May 22, 2007 | 03:28 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
depends on ur numbers... tranny might not be too happy. get a transmission cooler to help a little bit, but youre gonna have to build it at some point if you want that boost.
Old May 22, 2007 | 04:23 PM
ASUSMC's Avatar
ASUSMC
I run 10psi on a stock motor but I am a 5 speed...
Old May 22, 2007 | 04:54 PM
nanaki's Avatar
nanaki
Retired MF Moderator
keep in mind, there's no guarentee your motor or tran will hold up even with 350RWHP.
Old May 22, 2007 | 05:12 PM
amoosenamedhank's Avatar
amoosenamedhank
When you say "stock" do you mean stock short block or complete stock car. If you are referring to the car described in your sig I would say you should be ok. The long tubes and the intercooler will help a lot to preserve the engine. Transmission cooler will help a lot as well. Like it has been said before though, it's all in the tune.
Old May 22, 2007 | 05:38 PM
nanaki's Avatar
nanaki
i'm referring to stock shortblock. there's no guarentee any amount of power will be "fine". you see 05+ GTs running around with 500+RWHP with no problems with the norm being around 450-460. my stepdad's threw 2 rods at 408.
Old May 22, 2007 | 06:54 PM
Fizzics Boy's Avatar
Fizzics Boy
My friend who owns an 04 Mach1 threw a rod in his. I forget how much boost he was running though.
Old May 23, 2007 | 01:31 AM
White02GT's Avatar
White02GT
what would the 10 psi dyno around with a power pipe
Old May 23, 2007 | 01:33 AM
svt_97cobra
I ♥ Acer
If you get a power pipe that will be even more boost
