cai causing blown engine???
Old Dec 24, 2004 | 05:30 PM
dan's Avatar
dan
Default cai causing blown engine???
i heard from somone that they put a cold air intake on there car and they went over a puddle and water got in there engine and it destroyed the car. I also heard that you cannot drive in the rain.
Old Dec 24, 2004 | 05:32 PM
Stinger's Avatar
Stinger
Default RE: cai causing blown engine???
well if the went 4X4 sure it could happen.[8D]i havnt heard of anyone getting a blown engine. Would need to suck down alot of water.
Old Dec 24, 2004 | 06:16 PM
red2k1gt's Avatar
red2k1gt
maybe if you were trying to drive through a lake...
Old Dec 24, 2004 | 06:17 PM
grabbem88's Avatar
grabbem88
a little bit of water is not going to hurt it.
Old Dec 24, 2004 | 06:19 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Well it floods here in Tx where I live ALL the time when it rains and I have to drive through some deep water from time to time. My filter gets wet and so does the MAM and it throws the A/F ratio and turns the CE on. I just park mine and let it sit till it drys and reset the code with my OBDII scanner. I would imagine you could blow it if the A/F ratio is way off.
Old Dec 26, 2004 | 01:01 PM
Skip2002GT's Avatar
Skip2002GT
That happened to this one GT that was around here.....he took it back to Ford and they barely replaced the motor for him since the CAI was still in place when he took the car in. I never thought it could happen until I heard about that incident.
Old Dec 26, 2004 | 03:07 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
for starters a CAI isn't gonna get any water in it unless the car is actually driven under water. the cai is in the fenderwell and on the newer GT's at least theirs no way for water / rain to get in unless you cut the bottom out of the wheelwell (and even then its only water mist which wont hydrolock an engine). So the bottom line is that unless you physically drive in water that will put the CAI underwater (like over the top of the tires) then theirs no way to suck in water. I actually cut the bottom out of my fenderwell to get more cooler air to the filter, I've been in some serious rain and no problems - nor will their be any unless I go off-roading or get stuck in a flood and drive the car through water - in which case CAI or not you'd still hydroloc.
Old Dec 26, 2004 | 03:40 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
LOL... Like I said, it floods bad here and my filter gets saturated. LOL
djbigskrilla
Sep 20, 2022 01:04 AM
Calizic
Aug 28, 2015 01:46 PM
daytooday
Aug 16, 2015 08:22 AM
05slpGT
Aug 12, 2015 02:32 PM
HIS S-197
Aug 10, 2015 05:47 PM
