Question about engine oil?
Old May 24, 2007 | 07:53 PM
dormeas's Avatar
dormeas
Default Question about engine oil?
Well to start this out I know it is a common subject but I did a search and did not turn anything up....so I will just ask.
Old May 24, 2007 | 07:54 PM
FrostByte's Avatar
FrostByte
Default RE: Question about engine oil?
ask what?
Old May 24, 2007 | 07:57 PM
handyandy's Avatar
handyandy
Old May 24, 2007 | 07:58 PM
BlkGT2002's Avatar
BlkGT2002
Good question[:@]
Old May 24, 2007 | 08:05 PM
dormeas's Avatar
dormeas
Sorry don't know what happened there, anyway....
I just bought my car with like 40,000 miles on it and changed the oil as soon as I got it home. I used the 5W20 Mobil 1 fully synthetic. I now have about 42,500 miles on it and have added a full quart to keep it up to full. Is this bad for my car to be using this amount of oil. I have checked and am sure there are no leaks. Should I be running a little thicker oil like the 5W30 because of my miles or what?
Old May 24, 2007 | 08:10 PM
handyandy's Avatar
handyandy
nah I'm pretty sure you are just fine. I have 100,000 on my 2001 and I never burn oil, I use the recommended amount of oil (i forgot what it is) and its all good. I use synthetic blend.
Old May 24, 2007 | 09:02 PM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
i dont understand, did u put enough to get it "full" the first time, and now ur 1 quart low? is ur question, "why did i burn a quart of oil" ??
Old May 24, 2007 | 09:46 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
What year is your car, how much did you put in when you changed it? Ford changed the oil pan in mid-'01 and the engine oil capacity went from 5.0 to 6.0 quarts...
Old May 25, 2007 | 12:43 AM
dormeas's Avatar
dormeas
I put six quarts in when I changed it. So yes I would like to know if it is common to burn somewhere between half a quart and one quart? Sorry I was vauge
Old May 25, 2007 | 05:41 AM
kylebgt's Avatar
kylebgt
ORIGINAL: cliffyk
What?? I have been putting in about 5.7q's, I figured that the oil filter holds 1/4 quart or so. Am I putting in too much? By the way Mobil1 is good stuffI used to always use Castrol but have had bad experiances with it (not on this car). I have 86k miles and don't burn any, maybe your piston rings are wearing down[:-]
