one wheel spinning?
Old May 31, 2007 | 05:19 PM
02ToRcHgTSLP's Avatar
02ToRcHgTSLP
Default one wheel spinning?
I have an 02 GT with stock axel ect. When I bought the car and I did a couple burn outs I left 2 tread marks. I just did a burn out the other day and only left one....I did a couple more and still only the right wheel leaving marks. What could be wrong with my other wheel for it not to be spinning anymore????
Old May 31, 2007 | 05:21 PM
P Zero's Avatar
P Zero
Default RE: one wheel spinning?
The limited slip inside the axle is worn out, it needs new clutches.
-P.
Old May 31, 2007 | 05:26 PM
BleedinBlue's Avatar
BleedinBlue
ORIGINAL: P Zero
-P.
Yup. Get gears and get the posi rebuilt when they are getting installed.
Old May 31, 2007 | 05:31 PM
02ToRcHgTSLP
how much would it cost roughly to get the posi rebuilt or should i just get an auburn posi put in to while i'm gettin the gears?
Old May 31, 2007 | 10:10 PM
GStam66's Avatar
GStam66
i thought the clutch rebuild kit (45) would be enough? but they want 250 to do it... [:@]
Old May 31, 2007 | 10:38 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Get something a little stronger than a clutch-diff if you're going to spend the money.
FYI, multiple burn-outs on somewhat sticky road surfaces will destroy your Trac-Lok very quickly.
Old May 31, 2007 | 11:46 PM
99gtstang's Avatar
99gtstang
ORIGINAL: 02ToRcHgTSLP
my mechanic told me clutch replacement not worth it... buy a new posi i think there from 200-300
might as well buy the gears and get it all done at once
i was quoated 600 for posi, 373s installed and they supplied parts.. but without posi i paid 400 but i think that was a little cheap
Old Jun 1, 2007 | 12:23 AM
1BadSonicBlue02GT's Avatar
1BadSonicBlue02GT
dont buy crap from a shop. get a nice solid rear.
Old Jun 1, 2007 | 12:33 AM
cammed99gt's Avatar
cammed99gt
U can get a eaton 31 spline/31 spline axles/bearing and shimskit/gears for $800-900.Then u can throw all kinds of abuse at it and not worry.I just order all my rearend stuff in the last couple of days
Old Jun 1, 2007 | 01:29 AM
GStam66's Avatar
GStam66
well im kinda ****ed here, cause im only gettin one-wheel peels, and its wearin out one tire kinda fast. I need better tires, but then ill just burn up one good tire instead of 2... i also need to get 2-wheel drive too. [&:]
So ur sayin to get a whole new t-lok setup and not just new clutches?
