dash pieces paint prep
Old Jun 4, 2007 | 08:28 PM
01stalliongt's Avatar
01stalliongt
Default dash pieces paint prep
anyone that has painted inside pieces did you sand them down first
Old Jun 4, 2007 | 09:48 PM
4.698GT's Avatar
4.698GT
Default RE: dash pieces paint prep
It is not necessary to sand them down, but you should at least hit them with a scotch pad. Its just a small abrasive pad that is usually reddish in color and available at most auto part stores. Just give it a good one over with one of those and you should be good to go with the paint. Just spray it litely and let it cure before applying coats. Patience equals a good paint job.
Old Jun 4, 2007 | 10:42 PM
2VNA's Avatar
2VNA
why would you paint the inside pieces. it will scratch very easly and look like crap after cleaning a few times.
Old Jun 4, 2007 | 10:54 PM
Eminembdg's Avatar
Eminembdg
if you are painting plastic you should use Krylon Fusion spray paint for the parts you can take out of the vehicle to paint ( because of the overspray). It's made specifically for plastics and actually doesn't need any prep work. It bonds to plastic at a molecular level. It's really great stuff and is good for interior or exterior surfaces. It won't scratch easily if done right and can withstand cleaning.
Old Jun 4, 2007 | 11:06 PM
wwmost's Avatar
wwmost
ORIGINAL: 2VNA
wrong.... if done right it is as good as any stock piece. i just whiped my pieces down with rubbing alchohol and sprayed 5-6 light coats of duplicolor import spray and then put 3 clear coats on top of that. you have to put a clear so that it protects from scratches.here is how mine turned out https://mustangforums.com/m_3202563/...tm.htm#3202563
Old Jun 4, 2007 | 11:41 PM
5speedstang's Avatar
5speedstang
i did the same as wwmost, i took the pices out, wiped them with prep sol. and did a few light coats to get some paint on than did about 4 heavy coats, than came the clear. i did about 7 coats of clear on all the piecs. and came out awsome.
Old Jun 4, 2007 | 11:51 PM
marcuslee842's Avatar
marcuslee842
I painted mine the same color of my car but I'm not satisfied with how it came out. I did a decent job but I painted too much. I won't dare post any pics. lol
Old Jun 4, 2007 | 11:55 PM
gera8712's Avatar
gera8712
where can i get the clear spray??? in autoparts store maybe???
Old Jun 5, 2007 | 12:00 AM
gera8712's Avatar
gera8712
[sm=ttiwwp.gif]
ORIGINAL: 5speedstang
Old Jun 5, 2007 | 01:00 AM
4.698GT's Avatar
4.698GT
Only picture I have that you can actually see them in. I only did those two because there the easiest to get to and are like dead center in the door. I think its looks good, breaks up the tan some and get its a little extra
