How many times does your car crank before it fires?
Old Jun 11, 2007 | 07:55 PM
Triisomy21's Avatar
Triisomy21
Default How many times does your car crank before it fires?
Exactly like the title says. I have to hold my key for about 3 seconds before it finally fires. It never happend before the blower install. It's not the fuel pump because I drove around with it when I was still stock. The plugs are at .035 and the injectors seem to be seated all the way...no leaking.
Any ideas what it could be? It's more of an embarrassment than anything else.
Old Jun 11, 2007 | 08:19 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Default RE: How many times does your car crank before it turns over?
Cranking and "turning over" are classically the same thing--starting,running, and "firing up" are usually the expressions used for what is supposed to happen next (the Brits say "ticking over" happens after cranking)...[/align][/align]In any event, my '03 GT usually cranks for less than 1 second (more like 1/2 to 3/4) before starting. Although rarely,whenthe engine'shot and has only been stopped for a few minutes, it will require 2-3 seconds before it fires--I've found this to be a somewhat common issue with many EFI cars...[/align]
Old Jun 11, 2007 | 08:28 PM
Triisomy21's Avatar
Triisomy21
oops, sorry about the terminology. It's weird because it's never done it before. Hell even after it sat all winter it fired right up.
Old Jun 11, 2007 | 09:03 PM
massmustang02's Avatar
massmustang02
Could be the ignition.
Old Jun 11, 2007 | 09:37 PM
sstang's Avatar
sstang
Mine as well takes a few seconds to get started here and there... usually when people are around [:@]
Old Jun 11, 2007 | 09:41 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
this is a common problem. nobody seems to know why it happens or wtf the solution could be. it has been posted many times... but the answer has not.
Old Jun 11, 2007 | 10:03 PM
964.6gtstang's Avatar
964.6gtstang
dont know much about 4.6 but it might be timming i had that prob with my 5.0 my 4.6 i had to start it twice cause th fuel pump so i changed it now it starts right up
Old Jun 11, 2007 | 10:39 PM
beastzilla02's Avatar
beastzilla02
so gay mine does it 2. i ****in hate it.
Old Jun 11, 2007 | 10:47 PM
Rusmisel01GT's Avatar
Rusmisel01GT
I might have misunderstood... Do you have a stock fuel pump with your blower?
Old Jun 11, 2007 | 10:58 PM
Triisomy21's Avatar
Triisomy21
negative, svt focus. I installed the fuel pump a week or two before because I wasn't sure I was going to keep the blower but still wanted to install something (i get like that).
Anyway, it was fine and now it cranks like ten times before it fires.
