Little problem
Well I just notice that the hose runing to the PCV valve when the car turns on get kinked as if something is cloging it I checked the hose and it seems fine. It kinks right were it turns it to the rubber hose from the hard plastic one. Has anyone else had this problem? Any help would be appreciated.
You're just pulling a vacuum through that hose and it's "kinking" at a weak spot. Take the line off, pull off the rubber elbow and snip off the kink in the plastic line. You should have enough slack left over to reinstall.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
