installing plenum
Old Jun 18, 2007 | 10:56 PM
99gtstang's Avatar
99gtstang
Default installing plenum
there is no egr gasket there was not one when i took original off either? Get one or go metal to metal?
Old Jun 18, 2007 | 10:59 PM
04SBGT's Avatar
04SBGT
Default RE: installing plenum
A gasket is probally not a bad idea... i think you would most likely spring a leak with the metal to metal idea. just my .02
Old Jun 19, 2007 | 12:05 AM
99gtstang's Avatar
99gtstang
oh well i put it on just for the hell of it. and yes i am getting that whistl from somewhere when i give it gas.
Not sure where yet.
Does anybody know where i can find a IAC gasket, and a EGR valce gasket?
Thanks
Old Jun 19, 2007 | 12:06 AM
TheMustangLoveR's Avatar
TheMustangLoveR
Dude the whistle is probably the load of air rushing into your manifold.
Old Jun 19, 2007 | 01:28 AM
WAG03GT's Avatar
WAG03GT
Its prob a leak between the TB and Plenum [&:]
Old Jun 19, 2007 | 03:01 AM
l0gik2's Avatar
l0gik2
Its probably just the new sound of the intake from the increased air flow. Unless it sounds "odd" haha! When I put my new bbk tb/plenum on it sounded quite a bit different, a lot louder suction sound.
Old Jun 19, 2007 | 03:02 AM
Sap's Avatar
Sap
Use a gasket, any air past the maf that leaks is going to cause problems.
E.
Old Jun 19, 2007 | 09:07 AM
99gtstang's Avatar
99gtstang
ORIGINAL: Sap
E.
i can't find one
Old Jun 19, 2007 | 11:04 AM
OzzDOA's Avatar
OzzDOA
Just make one out of a cereal box or other piece of thin cardstock. Easy-peasy.
Old Jun 19, 2007 | 12:37 PM
TheMustangLoveR
I think any hardware store would stock gasket maker material. It's just a big piece of gasket material and you can cut out the shape you need. Or you can get some silicone gasket material (that comes in tubes, can find it near thread lockers, etc.) but you need to make sure that you don't flood it with the silicone because it might seep quite a bit into the port and cause restriction of flow.
