engine pre ignition
Old Jun 18, 2007 | 11:44 PM
ssu2slo's Avatar
ssu2slo
Default engine pre ignition
hey i have a 2001 mustang with alot of intake mods such as manifold, plenum, throttle body, 80 mm mass air kit and accell ignition and was wondering being that my car is running lean would a larger injector stop this pre ignition by makeing the car burn a little richer
[align=left] [/align]
Old Jun 19, 2007 | 01:36 AM
945LSTANG's Avatar
945LSTANG
Default RE: engine pre ignition
get it tuned
Old Jun 19, 2007 | 08:24 PM
ssu2slo's Avatar
ssu2slo
i know getting it tuned would solve the problem but im kind of short on money and because of the lack of serious mods i would have to get it tuned again later and i was just curious as to if the injectors would solve the problem for the time being
Old Jun 19, 2007 | 09:06 PM
jacrockett's Avatar
jacrockett
Detonate that motor, and you'll reaaaaaly be short of money.
Get a tune.
Old Jun 19, 2007 | 09:15 PM
99StangGTTN's Avatar
99StangGTTN
Technically yes it would solve the problem if you go bigger. But if you go too big it will run too rich. The best thing to do and I can't see how it would cost much more than injectors would be to get a tune. Do it right before you cause major damage or take some of the things off until you have the money to do it right.
Old Jun 19, 2007 | 10:31 PM
ssu2slo's Avatar
ssu2slo
i would like to get a tune i ordered 26lb injectors i hope those arent too big in the long run a tune is definitely goin to be needed but i would like to wait until i put a set of heads or a blower or something major before i do that i tried using a diablo tuner and cutting my timeing and uppin my fuel with that but that limits u to what u can too so i pretty much gave up on the diablo tuner when i get it tuned im leaning towards fastlane motorsports a couple friends of mine got their stangs tuned their and were really satisfied this weekend is fun ford weekend and i want it solved by then so im trying injectors for right now i dont think 26lb would be too big yaw think that would work also i might need those anyways to get a decent tune i think those factory injectors are holding my car back by not allowing enough fuel whats yaws opinion on the 26lbs
Old Jun 20, 2007 | 12:18 AM
99StangGTTN
Your car will probably run too rich now. Just upping injectors will add fuel but it won't be tuned correctly resulting in poor drivablity and other things. I would seriously just take the 80mm maf off until you get it tuned. You aren't picking up big gains if anyfrom it so whats the sense? If you already have a diablo just richin it up a bit and keep an eye on it. Actually by changing your timing and it running too rich would probably hurt the car more than any gain you receive from the MAF.
Old Jun 20, 2007 | 02:28 AM
oxfordgt's Avatar
oxfordgt
Get rid of the 80mm maf.You dont need it yet and if you dont have the money for a tune you are going to blow your motor.
Old Jun 20, 2007 | 02:32 AM
2000GT4.6's Avatar
2000GT4.6
Take the 80mm MAF off and put the stocker back on. its the cause of your a/f condition.
How do yuo know the car is lean?
So far as injectors, you cannot just throw in a bigger set of injectors without a retune, all thats going to do is completely screw everything up.
Old Jun 20, 2007 | 02:50 AM
piledriver's Avatar
piledriver
Banned
ORIGINAL: jacrockett
Get a tune.
No offense, but pre ignitionis detonation.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
