A/C Recharge Questions
Old Jun 19, 2007 | 04:48 PM
AWD4g63's Avatar
AWD4g63
Default A/C Recharge Questions
The motor was just replaced in my 00 GT. The ac lines were disconnected. Can I just recharge it or do I have to bleed the system. I've never done this before so I'd like to know how much of the R134a I would need,
Thanks in advance,
Mike
Old Jun 19, 2007 | 05:27 PM
Eduardo's Avatar
Eduardo
Default RE: A/C Recharge Questions
I would like to know the same thing, I just replaced my a/c compressor too man lets see if anyone can help us out...
Old Jun 19, 2007 | 08:38 PM
2003GT100's Avatar
2003GT100
Realistically you should have the system put under vacuum by a shop so the system can be tested for leaks.
Old Jun 19, 2007 | 08:45 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Pulling a vacuum on the system for 30 minutes or so ensures that all moisture has been removed--it literally "boils" any moisture from the system.It is not 100% necessary, however if the system has been flat and open to the atmosphere for some time, and depending on the relative humidity where you live, not doing so can lead to very poor performance (a/c performance, not the motor) and can even damage the compressor and valving...[/align][/align]It is the proper way to do it, if the system was open for any period of time then it's close to essential...[/align]
Old Jun 19, 2007 | 10:40 PM
sprostang's Avatar
sprostang
I ♥ Acer
Really, it is aMUST that you pull a vacuum. If you don`t, the moisture/air that is in the system will for sure kill the compressor in time. Filter dryer should also be changed if the system has been open to the atmosphere.Best way to check for leaks it to put dry nitrogen in the system, watch your guage to make sure the pressure doesn`t drop after you fill it with the nitrogen,also put some leak detector around all the joints to make sure there are no leaks. Dish soap will work for looking for a leak as well.
baddog671
Jul 26, 2016 01:20 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
