2V Buildup thread
So as many of you know I broke a piston in the stock motor. The car still runs and at this point I am still driving it. I have already decided that I am gonna build this into a pump gas beast of a 2V. The car is gonna get longtubes, cams, a built shortblock, and maybe a few more pounds of boost!!
Already purchased:
CHP shortblock. 5.1L stroker (thanks again to Ethan and Bill from Stage3)
Pacesetter longtubes (thanks to Ethan and Bill from Stage3motorsports who got me a great deal on em)
Pending purchases:
VT stage III blower cams (guy on M0dular F0rds)
Still need to buy:
Set of high lift Valve springs (for the larger cams)
Probably need one Windsor head (from the broken piston)
So if anybody knows where I may be able to get some of this stuff for a good price let me know.
Already purchased:
Pending purchases:
Still need to buy:
unless your just getting a insanely killer deal on the cams (and even if you are) you should look into some custom grinds. They are basically the same price as a set of new "stage x" ones, but will be customised to your setup to make the most power.
$400 for the cams...
I probably will port the heads a little bit while they are off of the car. But I already know who is gonna do that so thats why I didn't put them up there
Bought the CHP shortblock. 5.1L stroker using Manley rods, Probe Pistons notched w/ low compression.
Plus a bump to see if anybody has any idea about any of the other stuff.
ORIGINAL: ASUSMC
ORIGINAL: ASUSMC
I am gonna get the heads ported and redone, new seals, valve springs, cams.
