blower noise
ORIGINAL: jpmustanggt
http://s63.photobucket.com/albums/h1...rent=ac002.flv
Listen at the very end. Is that weird?
I made a small vid clip for you....sounds like mine...yours is louder.
http://s76.photobucket.com/albums/j4...rent=Movie.flv
Did they send you an invoice telling you EXactly what they replaced?Didnt you have metal run threw it?I would think they would had to replace EVERYTHING inside.....Kinda likerear end gears....pinion bearings fails,,or carrier bearings,,,metal runs all through the rear,,replace bearings but not the gears.....still end up with a whine becauseof the metal that ran through the gears...I'd call them first,if you do sell.,.,,,,,what then?
The bearings went bad in it and they did a minor rebuild on it, bearings and seals. I almost bought a Jeep today before the payments fell through. So I'll probably just buy a nicer one of those.
