Automatic Question.
Old Jul 10, 2007 | 11:29 PM
White02GT's Avatar
White02GT
Default Automatic Question.
What would i have to do to my automatic to make it strong for more hp and how much would it cost?
Old Jul 11, 2007 | 11:02 AM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
Default RE: Automatic Question.
swap for a 4R75W, stall converter, torque converter, shift kit, transmission cooler for starters. this will be in the thousands
Old Jul 11, 2007 | 06:10 PM
silverstang1996's Avatar
silverstang1996
or you could only spend a few hundred and just have a shop build your transmission with stronger parts. it costed my brother $100 to have his done but he was a relative of ours and he had one of the C4 trannys, but it should only be in the hundreds.
Old Jul 11, 2007 | 06:13 PM
2002GTAUTOVERT
$100 dollars for a rebuilt tranny? where are these magical rebuilds taking place?? in candyland?? lmfao. you think "stronger parts" is all you need.... ok good luck with that. you get the stronger parts and leave the stock TC and no tranny cooler and we will see how it lasts. good luck
Old Jul 11, 2007 | 07:09 PM
97stanger's Avatar
97stanger
I agree with both of you, start with gears, stall, shift kit, tranny cooler. Then just get your current one rebuilt, which shouldn't be more than 300-500. Thats what my buddy did and his 500rwhp stang is holding up fine...
[/align]
[blockquote]I[/blockquote]
Old Jul 11, 2007 | 09:06 PM
01Steed's Avatar
01Steed
I ♥ Acer
go to tccoa.com, click on the Tech Articles section, and read the Transmissions 101 stuff, chapters 7-12 I believe. Also, read up and do the j-mod.
A tranny rebuild will run you atleast $800, and you'll need a good stall converter (multi-disc). Count on another $850 for that....I recommend a DirtyDog converter. Also, a good cooler. I use the Fluidyne "9-pass" ($90'ish) and bypass the radiator altogether.
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
