Compression Ratio
Old Jul 21, 2007 | 09:36 PM
99mustanggt's Avatar
99mustanggt
Default Compression Ratio
Hey guys, what size dished pistons will produce an 11.5 to 12:1 compression ratio.I'm thinking somewhere around 5cc but I'm not sure.Any help would be greatly appreciated. This is for a 99 GT 2v.
Old Jul 21, 2007 | 10:39 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Compression Ratio
5cc will giva ya right at 11.25:1
Old Jul 22, 2007 | 05:21 AM
contentsunderpressur's Avatar
It depends on what brand piston you go with. For example: A 15cc Diamond piston produces the same compression ratio as about a 17cc Manley piston. Scott from VT engines told me this. Manley claims there flat top piston makes a 10.5 compression ratio, so you would have to go with a pop top piston from them to get that ratio.
Old Jul 22, 2007 | 09:44 AM
01Steed's Avatar
01Steed
I ♥ Acer
There are some small variances in tolerances, and one company may be machining their pistons on the small side, and the other on the big side.While a 2cc variant would be alot, it is within the OEM spec'd tolerance. But, the only way to estimate the c/r is to use nominal numbers. If Manley advertises a 17 cc volume, then that's what you have to use in your calculations.
That being said, you'll want to go with something like a 1.8 cc to put you in the range you've defined. An aftermarket flat-top will net you a bit over 12:1.
Don't mess around with head gasket thicknesses. Leave them of stock thickness. I'd recommend you use an OEM gasket anyway. 4C2Z-'s are what you want.
Old Jul 22, 2007 | 09:58 AM
David_K's Avatar
David_K
call JE and theyll make you some your looking at domed pistons though
Old Jul 22, 2007 | 10:41 AM
99mustanggt
Hey thanks alot guys.Im still not sure if i want to go N/A or turbo but I'm trying to add everything up to see how much each will cost.
Old Jul 22, 2007 | 12:10 PM
01Steed's Avatar
01Steed
I ♥ Acer
Well, you'd better make up your mind before you select a piston, 'cause you won't be able to run 11.5:1 to 12:1 c/r with a turbo.
David_K, why would he want a 'domed' piston? He can achieve 12:1 with a flat or near flat piston.
Old Jul 22, 2007 | 12:33 PM
01Steed, why do you think a flat top manley will put him at 12:1? Manley told me that a flat top would put you at 10.5:1 so it would take a dome piston to make 12:1.
Old Jul 23, 2007 | 08:27 AM
01Steed's Avatar
01Steed
I ♥ Acer
We're talking about 2V's here, not 4V. Flat tops in a 4V will net approx. 10:1-10.5:1.
Old Jul 24, 2007 | 04:58 AM
ORIGINAL: 01Steed
Your right, 4v has a much bigger combustion chamber.
