Stuck E-Brake!! PLZ HELP!!!!!
Old Jul 21, 2007 | 11:46 PM
josh662234's Avatar
josh662234
Default Stuck E-Brake!! PLZ HELP!!!!!
Well i just went to push my car into the garage because it is too late to start it. When i started to push i got that squeeking sound like the e-brake was still on a little. i checked and it was not. i am getting this squeek from both sides. How can i free it up. Maybe this is keeping me from 13's? lol
Old Jul 21, 2007 | 11:53 PM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
Default RE: Stuck E-Brake!!
when you pull your ebrake, is there slack in the line?? i.e. does the handle come up a half inch or so before you feel tension???
Old Jul 21, 2007 | 11:58 PM
LetThePoniesRunFree's Avatar
LetThePoniesRunFree
ORIGINAL: josh662234
Sounds normal to me. Your rear e-brakes are controlled via a cable with a return spring on the caliper, not hydraulics. Tomorrow when you can start the car without waking the neighbors up, release the e-brake, start the car, pump the brake pedal a couple of times, shut the car off and let it roll out of the drive way. I'll bet your "squeeking" sounds goes away.
Old Jul 21, 2007 | 11:59 PM
josh662234's Avatar
josh662234
well i just checked and when i pull it up there is some tension. . not much. . . i dont get a click until about an inch and a half up. . .
Old Jul 22, 2007 | 12:03 AM
josh662234's Avatar
josh662234
ORIGINAL: LetThePoniesRunFree
Thank you.i'll try that in the A.M.
Old Jul 22, 2007 | 08:59 AM
MineralGrey's Avatar
MineralGrey
if those tricks don't work try loosening the cable if that doen't work than it might be your pistons are locking up maybe the person who did your brakes before didn't push in the piston the right way.
Old Jul 22, 2007 | 03:10 PM
josh662234's Avatar
josh662234
how do i loosen the cable?
Old Jul 22, 2007 | 09:07 PM
josh662234's Avatar
josh662234
anybody??? i tried turning the car on, pumpin the brakes, then turning it off. i can rock in my seat and hear it squeak. it's definitely sticking!
Old Jul 22, 2007 | 09:28 PM
MineralGrey
you should be able to see your cable through your armrest compartment take the bottom of it ou and you should see the e brake cable(s) and basicly left loosey righty tighty, but also consider that the pistons might be siezing up, if they are and you decide to reinstall new calipers your self you have to push and twist the rear calipers piston in order for it to function properly.
Old Jul 22, 2007 | 09:47 PM
99mustanggt's Avatar
99mustanggt
Are you sure the brakes are sticking and not just worn down to the wear indicators?Just a suggestion.
