Sounds like you may have a custom tune. The LED is on when the t/c is off (I guess it's supposed to be a warning)--when turned permanently off via a handheld tuner or custom tune you cannotenable the traction control, the light stays on...[/align]
i had the same problem when i bought my car. They said it had something to do with a sensor. . i'm not sure how true that was because it happened for a few days after they "fixed" it . . mostly when it rained out. . . then it just sorta fixed itself
One way to tell if it's throwing a false code or not is to do (or try to do) a burnout. If you light em up, then you probably have a tune, and it's disabled...if not, you may have a problem.
