Need some HELP, hit the curb!!
Old Jul 27, 2007 | 10:09 PM
SidGT's Avatar
SidGT
Default Need some HELP, hit the curb!!
I need some help. I recently hit the curb damaging the rear right wheel. I slid into and over the curb, hitting pretty hard. Wheel was gone, axle was replaced, brake caliper bracket replaced however my brakes still rub against the rotor only on a certain spot.
I noticed there is a small gap between the diff and the caliper bracket. Is there supposed to be a gap.
Any way around getting a new diff and if not, how much should it cost to replace. Thanks for the help.
BTW, did not replace the axle bearing or seal, if that helps
Old Jul 28, 2007 | 01:18 AM
tmas99's Avatar
tmas99
Default RE: Need some HELP, hit the curb!!
did you replace the rotor... the rotor might have bent or be warped...
Old Jul 28, 2007 | 06:05 PM
SidGT's Avatar
SidGT
that's what i was thinking too, but my mechanic said he really doubts it. He said the rotor would have cracked or broken completely.
The only thing is that i'm not sure about that gap between the bracket that holds the calipers and the differential. My mechanic said hes pretty sure its supposed to sit completely flush with no gap (even though its a tiny gap) so according to him i need a new differential.
Old Jul 28, 2007 | 09:36 PM
SidGT's Avatar
SidGT
actually he swapped the rotors and calipers and the brakes still rubbed. The strange thing is that they only rub on one spot on the rotors.
Old Jul 28, 2007 | 09:51 PM
Dirtybird54's Avatar
Dirtybird54
May be a possibility that the rotor wasn't installed properly or the caliper is misaligned. Could be any number of things but its a brand new rotor it shouldn't be doing that.
Old Jul 29, 2007 | 12:30 AM
tmas99's Avatar
tmas99
yeah no... there should be no gap at all.. i know that for sure... that bracket bolt will fall out and then you have a bigger issue... if that bracket falls out then you will bend it even more and then the caliper might get messed up to... if those parts are under warranty i would send it back and get new ones... no point in meesin any more things up then already are... it sounds like the rotor is messed up if the bracket is alighned with the rotor... idk though...
Old Jul 29, 2007 | 11:06 AM
prochargedGT's Avatar
prochargedGT
well a new diff (good one) installed would be around 1000$
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Sep 30, 2015 12:39 PM
Dan04COBRA
Sep 30, 2015 11:46 AM
wraith777
Sep 28, 2015 10:49 AM
