PROBLEMS with reverse
+1 on first gear works for me everytime... also i find it easier to put it into gears when the car is off so put it in reverse before you turn the car on BUT don't forget that you have it in gear and take your foot off clutch, otherwise you stall and look like an a**, like i have done a couple of times haha
I wouldn't do that. The tranny fluid isn't running when the car is off, so if you play with the gears when it's off you could damage them. At least, that's what I've been told and it sounds right.
As for the problem at hand, everyone seems to have their own ways. My way is putting it into first, moving the car ever so slightly forward and then put it into reverse. What you need to do is get the tranny to line up right, so that seems to do the trick for me. Either that, or if you're on a hill you could let the car roll forward or backwards a bit and then put it into gear. Either one has worked for me, though. Hope this helps.
reverse is syncronized in the T-45 transmission....
personally, i think part of the problem is that the reverse gears are not straight cut so the helical reverse gear gets pushed out. Any gear would work to help get it in reverse. i perfer 5th just because there is no lock out and you can slide it straight back into reverse which is the fastest way. And if you go 5th to reverse you can slam it into reverse which works pretty well since these transmissions seem to like to be manhandled....
