midpipe install
do the 99 + GTs have a manifold to midpipe gasket on the passanger side or do i not need to worry about gaskets.... i could have sworn that the 99+ didnt use any gaskets in the exhaust... someone told me i need to get that gasket but that goes against what i thought... so if i do infact need that gasket let me know. if the entire exhaust system on the 99+ is gasket free... let me knwo... either way .. let me know lol
thanks guys
thanks guys
Yeah they are oval shaped with a perferated rasied seal. I didn't replace mine the first time and it leaked when I went to put in the new one the peferated center broke out of the old one. It was a bitch because I couldn't get my hands up to disconnect the front O2s and had to do it with the pipe still in place[&:]
i just called santa monica ford and they said there is no gasket for it ? what kind of sense does that make.... he said its just a flange and thats it ... which my pipe does come with ... not gasket though... is he dreaming? if so... where can i get a gasket and bolts and studs online... i called napaonline and they dont have either ... let me know . thanks
ORIGINAL: SilverGTV8
passenger side manifold midpipe- to-manifold is the only one with a gasket. You should get one from Ford or 50Resto.com. you won't find it at an autoparts store.
and for 3bucks I would rather have 2 then none when I needed it.
