bought 4.10s
Old Aug 20, 2007 | 03:43 PM
Twogunsblazin's Avatar
Twogunsblazin
Default bought 4.10s
just bought a set of motive 4.10s off american muscle. I bought an install kit too with new gaskets and what not. is there anything else i would need to replace while installing the gears? or would evrything else be fine stock? thanks guys
Old Aug 20, 2007 | 04:01 PM
Twogunsblazin
Default RE: bought 4.10s
anyone?
Old Aug 20, 2007 | 04:46 PM
tbirdscwd's Avatar
tbirdscwd
If you have a complete kit with bearings, shims, seals, and all that, you should be good.
Old Aug 20, 2007 | 09:35 PM
GhostRider02GT's Avatar
GhostRider02GT
dont forget the dial indicator if you dont have one, otherwise those puppies will WHINE, congrats by the way, Im envious...
Old Aug 20, 2007 | 10:09 PM
97stanger's Avatar
97stanger
tuner/speedcal...your speedo will be off
[/align]
02ToRcHgTSLP's Avatar
02ToRcHgTSLP
whats a dial indicater? does it come with the install kit?
Old Aug 20, 2007 | 10:40 PM
GhostRider02GT
its a tool used by an installer to check backlash in the gears. That is the space or movement between the the ring gear and the pinion gear. How much will it move, before it starts to move the other gear. The dial indicator measures that distance of movement very finely I beleive the 100's or 1000's of an inch, I cant remember. But you would add shims to one side of the other to adjust the backalsh to get it into spec. He wont need it if hes not installing it. if he is installing it himself, he'll need something like it
Old Aug 20, 2007 | 10:41 PM
Shawn02GT's Avatar
Shawn02GT
this is a dial indicator http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=27844938they're used to measure run-out typically. you'll need one of these to measure the backlash if your doing the install yourself.
don't forget the fluid!
Old Aug 20, 2007 | 10:57 PM
Seth//00GT's Avatar
Seth//00GT
are you installing them yourself? its supposted to be a really delicate process that is easy to screw up....?
Old Aug 21, 2007 | 02:44 PM
Twogunsblazin
yea im gonna be doin it with a buddy of mine. the speedo is gonna be messed up for another two weeks til i can buy a tuner, i cant spend all my money on the car unfortunately....... just a good chunk. I just got the axles replaced back in march, and when they did that they replaced the bearings too, so i think itll be ok.
