CAR SHUTS OFF
HI, My car has been shutting off on me recently. It only does it sometimes. like 1 in 8 starts. It only does it on cold starts. I turn it on and then it shuts off right away. I have to give it a little gas in order to keep it on. This started happening after I polished my plenum. Everything is connected right.
RE: CAR SHUTS OFF
Is there a check engine light on?
RE: CAR SHUTS OFF
Take it to the shop. They have the gear to plug in to see what the problem might be.
RE: CAR SHUTS OFF
Have to have a CEL for any machine to tell you what's happening...
Start with your IAC. |
RE: CAR SHUTS OFF
no, there is no light. I will be taking it in for a tune soon. I'll have them look it over.
RE: CAR SHUTS OFF
Have to have a CEL for any machine to tell you what's happening... I would say maybe IAC. I havent replaced mine yet, but it does start then die every so often.. I know the symptons of an IAC. They are a huge downfall to FORD. Also DPFE. But i doubt thats the problem. |
RE: CAR SHUTS OFF
How much is a IAC?
RE: CAR SHUTS OFF
Just replaced mine today. I believe it was around $100 for the part and maybe 10-15 min for the install. Hope that helps.
RE: CAR SHUTS OFF
IAC could be the fault, but that is easy to check. TPS will do the same thing. That was the problem on my 90 5.8, TPS was erratic. Also simple to test.
Crap missed it by a few Millilitres. [:@] That engine is in the parts getter. You know how it is. The fukin trunk is too small to bring home the parts you need to keep the Mustang on the road! |
RE: CAR SHUTS OFF
1990 5.4? Holly hell, did you create that youreself?
and 100 bunx for an IAC is amazing. I was thinking more along the lines of 40 tops. But maybe the dealership you bought from screwed you. lol. |
