injectors
Old Feb 11, 2005 | 11:27 PM
Rushford's Avatar
Rushford
Default injectors
Would it be a good idea to get new injectors when supercharging. What would be a good injector to buy. 4.6L
Old Feb 12, 2005 | 01:59 AM
94Cbra's Avatar
94Cbra
Default RE: injectors
Multiply the number of injectors by the lbs/hr rating of the injectors, then divide that by the brake specific fuel consumption. For N/A engines the BSFC range is around 0.45 - 0.55 and for turbo/supercharged engines its from 0.55 - 0.65. According to that formula, 36# injectors could support up to 523 supercharged/turbocharged HP.
Old Feb 12, 2005 | 09:34 AM
BCisme's Avatar
BCisme
ORIGINAL: Rushford
you have to. the stock 19# cant flow enough fuel. 36# or 42# is what you want.
Old Feb 12, 2005 | 02:26 PM
Rushford's Avatar
Rushford
what size fuel injectors come with the vortech kit?
Old Feb 12, 2005 | 03:21 PM
Master's Avatar
Master
i would guess 42 cause the prochargers come with 42 and they real similar
Old Feb 12, 2005 | 03:29 PM
neogenic83's Avatar
neogenic83
unless u go over 9-10 psi the 36's will be fine on the stock engine.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
