car wont start
ive changed the batt changed the starter sometimes it will start sometimes it will not i just get a click sound and i also hear the fuel pump. any ideas?
RE: car wont start
try pumping the gas when ur starting it...
I had a problem like this with my car... it was my idler that was bad... I just banged on it with something hard and it started working again :D |
RE: car wont start
Hmmmm normally just a tick says battery, or started armature, but you chaged those. i am puzzled. i am going to check with a tech give me till tomorrow. i might have something for you if noone esle does.
RE: car wont start
Check your ground wire to the frame...Could be dirty. Also clean the wires on the battery if they are dirty (scrape them with a knife to get a nice shine).
RE: car wont start
Check all 3 nuts on the starter and make sure their tight
RE: car wont start
I'd kind of say you need to replace the starter. If it was a bad ground or bad connection, you wouldn't even get the click the times it doesn't start, you'd just get nothing. The click sounds to me like the starter is on it's way out, fast. It's a pain in the ass to change though, so give everything else a try.
