Nitrous Problems
Ok im having problems with my nitrous right now. This is what it does, If im in 4th gear at like 50 and I floor it once it gets to 3000 where my window switch is set at it begins to spray fine then all the sudden at like 5 grand it just dies it starts to jerk the car like its tryin to go and tryin to die then the system shuts down all together it hard boots the computer and I have to restart the car. Now I have a WOT and a window switch set at 3000-6000 aswell as a fuel pressure saftey switch. Now if im at the track and once I hit second and go full throttle nitrous dosnt come on in first because I do not floor it I get it to hook in first then run it in second, Well it starts to jump like the nitrous is hitting then its killin the car then it hits then the car dies then I just let off and drive down the track slowly. now I have stock injectors and stock pump still, when I checked the pump it was runin at 35 at like 3000 about 4 off of 39. Now I checked my pills and they are not clogged and the bottle was just filled and I cleand the line of air pockets before I ran. Maybe I need new injecotrs or maybe a fuel pump. I heard that a 100 wet shot would work on stock inj's and pump but maybe not
I am running a 100 shot with no fuel probs that i am aware of on a stock fuel system. Sounds like something is fubared with your window switch. Mine did the same thing when i hooked it up, minus the killing the car/ecu probs. I unhooked mine because i couldnt get it to work. If i was you I would look at the wiring/grounding on the window switch and the WOT switch. Thats the best place to start. Then i would look at the fuel pressure safety switch.
ORIGINAL: Bradley139
ill have mine next week is that normal? im not getting a window switch or should i? from the sound of it im better off without it
ORIGINAL: videoassault
Im going to try and bypass the window switch tomm and check to see. I have a MSD window witch on a NX kit but that shouldnt matter and I have it wired into 1
