need help check engine light is still coming on about the same problem!!
Old Oct 6, 2007 | 01:32 PM
clean97's Avatar
clean97
Default need help check engine light is still coming on about the same problem!!
Remember a while back about my thermostat was bad and that was the problem well since then I have replaced that new thermostat with a different one because the check engine light came on because the code reader said Insufficient coolant temp closed loop which means the car is running cold. And a week later after getting my new thermostat again the check engine came back on again for the same problem what should I do, I am thinking of selling this car because it is pissing me off, I understand that it is ten years old but i don't get it. I am looking through my motor and it does look like my car had a electrical fire before because the main charging system from my alternator to the battery, there is no wire and it looks like they wired the new charging wire through a different system. I know this is a lot of info at one time but ask me all the questions you want if you do not understand what I said in this paragraph.
Old Oct 6, 2007 | 01:44 PM
clean97's Avatar
clean97
Default RE: need help check engine light is still coming on about the same problem!!
I just pulled my negative battery cable off to reset the computer I have never done this hopefully it resets my computer then I will take it for a test drive.
djbigskrilla
Sep 20, 2022 01:04 AM
FD725
Aug 23, 2015 06:43 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
