Fuel Cutoff Switch
Old Oct 21, 2007 | 04:58 PM
Nitti00GT's Avatar
Nitti00GT
Default Fuel Cutoff Switch
Does anyone know how to reset the fuel cutoff switch. I don't have an owners manual.
Old Oct 21, 2007 | 05:01 PM
97targa's Avatar
97targa
Default RE: Fuel Cutoff Switch
It's in the trunk on the driverside near the taillight. Just push in the button. It pops for a reason, so I would get it checked out
Old Oct 21, 2007 | 05:03 PM
Nitti00GT's Avatar
Nitti00GT
Ok it is already pressed in so I should be fine right?
Old Oct 21, 2007 | 05:06 PM
97targa's Avatar
97targa
Like I said, it pops when something is up. Maybe a plugged sock from dirty gas, bad ground, too much pressure. I would use a scan tool to see if any DTC's have come up. You can get those without your check engine light coming on! If you have a handheld SCT that will check for them.
Old Oct 21, 2007 | 05:09 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
I didnt know it popped up on its own.
I know how to turn it off. lol
I just unplug it :-)
Old Oct 21, 2007 | 06:26 PM
Nitti00GT's Avatar
Nitti00GT
Yeah I have a hand held SCT. I'll try that. My next door neighbor's friend is a Ford mechanic so we are going to see if he can come out to look at it.
Old Oct 21, 2007 | 08:49 PM
2000GT4.6's Avatar
2000GT4.6
whats going on specifically? Just no fuel pressure, or what? Can't hear the pump starting when you turn the key to on?
Mine popped a few times in the past, for absolutly no reason. I would drive it to where I was going, get out, and when I got back in it wouldn't start. Reset the switch and everything was fine.
Old Oct 22, 2007 | 12:06 AM
Nitti00GT's Avatar
Nitti00GT
No the switch didn't pop and yeah when I turn the key I can hear the fuel pump. The starter just clicks once when I turn the key. My street is a hill so my buddies and I tried pop starting it and I have done it before on less of an incline at slower speeds and it worked but this time it wouldn't work. So even if it had a bad started shouldn't it still turn over if I pop start it? Also what made it just randomly die on me in the middle of a highway. I didn't hear anything mechanically breaking like the motor seizing or anything.
I was also thinking it might be the after market alarm that is on the car. I accidently cut a wire going to it before and when I connected the battery back up the alarm went off for the first time since I owned the car. So I had someone by-pass the alarm and I got it working again. We disconnected the alarm speaker cause it was making too much noise at the shop but the blinker still flashed when it was going off and it's not flashing when I try to start it this time so that's another reason why I am confused about what is going on.
Old Oct 25, 2007 | 12:16 PM
02ToRcHgTSLP's Avatar
02ToRcHgTSLP
sweet
4cylinderplus2
Oct 9, 2020 07:45 PM
PaulH2
20
Jan 31, 2016 09:48 AM
b8checker
Oct 8, 2015 12:55 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
