sputtering, misfiring? HELP PLEASE
i just got back from school and theres an open road that i usually like to give it a little gas.
well doing this my car started to sputter for a second then it caught and kept riding fine. this happend to my dad before so i just called him and he said we'll check it out. i just wanted to see what others think. he said maybe clogged fuel filter or plugs. any input is appreciated guys. |
RE: sputtering, misfiring? HELP PLEASE
how many miles does it haveand when was the last time you serviced it?
206xxx.
the last time it was serviced was when my dad still owned it. so about 5 months ago. only thing ive done was my oil changes. time for a tune up im thinking to see if that helps at all. |
i would change the fuel filter first, it seems like most people tend to forget to change it, if it still acts up after that, start looking at the plugs and wires
alright. im going to have to get it later tonight so ill probably do it in the morning.
ill go look in my mustang repair book and see what i have to do. |
Same thing happened to me, it doesnt happen all the time but occatsionally it will mis a beat on the road, Its most likely the spark plugs when where they last changed? <Thats what it was for me
haha, guess what i just found out.
my dad goes and tells me its been about 25,xxx miles since the plugs were changed. WTF? im hoping thats the problem. time to take matters into my own hands because this engine needs to run till i can get a new DD and start the work on the stang. thanks to you few that have given some input. |
Mine was doing what you're describing so I changed the plugs and now it runs like a champ. Sorry to jack your thread, but should you always change wires when you change plugs, or does it matter? I ask this because I just changed plugs and left the same wires for now.
Fuel filter is a possibility. Needs to be changed every 24k. Make sure there is no water in your plug wells and coil packs.
my car has done this twice now, each time it fixed itself. i dont know whats causing it, i was told possibly the spark plugs (once after i swapped intake manifolds, once after this weekend at the track). my guess is my problem is ignition related (either bad plug, bad cop, or something bad in ignition somewhere along the lines). threw a CEL code at me monday misfiring in cyl 1. agian, it fixed itself when i got in my car to go to dinner. i still replaced my plugs, cleaned the cops, well see if it comes back.
