ARGHHH!!! BRAKES CREAKING! (Video Added) FIXED IT!
Old Nov 5, 2007 | 07:41 PM
CobraStangGT16's Avatar
CobraStangGT16
Default ARGHHH!!! BRAKES CREAKING! (Video Added) FIXED IT!
http://www.youtube.com/watch?v=FqZn5Vj5lZw
WTF IS THIS SHYT IT'S DRIVING ME NUTS!
I have no clue what it is, and how to fix it. Anybody know?
Thanks guys.
Old Nov 5, 2007 | 07:52 PM
trickdriller's Avatar
trickdriller
Default RE: ARGHHH!!! BRAKES CREAKING! (Video Added)
Dude, that's friggen terrible! Do your brakes work now? Is there any drop in performance? If not, could it be something as simple as the pedal creaking somewhere?
Old Nov 5, 2007 | 07:57 PM
CobraStangGT16
The brakes work PERFECTLY!?!?!
Thats the only part that puzzles me! I can't figure it out! And it doesn't pull to one side if one caliper wasn't working right...none of that...[&:]
Old Nov 5, 2007 | 08:00 PM
catch_15's Avatar
catch_15
That sounds like my clutch cable in the mornings.
Old Nov 5, 2007 | 08:14 PM
JayBanion's Avatar
JayBanion
Thats rediclulious, and its only from one wheel? Time to rip apart your caliper. And haha did anyone ever play grand theft auto. Its the exact sound that the car makes when the guysgoing at it witha prostitute.
Old Nov 5, 2007 | 09:31 PM
CobraStangGT16
C'mon MF! You have yet to fail me!
Old Nov 5, 2007 | 09:45 PM
my99gt's Avatar
my99gt
I believe that it is just brake dust on the two bolts that the caliper rides on. You mentioned being at the track. With the brakes cold, spray them off with a water hose. Also, check to make sure that the caliper has not come loose. But, I'd almost bet it is just dust. BTW, car sounds good!
Old Nov 5, 2007 | 09:54 PM
CobraStangGT16
Thanks man! I'll try it right now! The car's been sitting for like 3 hours now.
Oh and just flowmasters with a catted x pipe and exhaust leak...nothin special! LOL.
Old Nov 5, 2007 | 10:09 PM
CobraStangGT16
Well I hosed it down pretty good, got in a pumped it a few times but got nothing.
Old Nov 6, 2007 | 12:10 AM
97targa's Avatar
97targa
ORIGINAL: CobraStangGT16
That's the problem. You need to pull the caplier off and put caliper grease on those bolts. Water will remove it after time as well as heat. If you run your brakes hard enough, you should regrease every so often. It is def. a caliper sound. I would say it's internal, but if it's not leaking you have nothing to worry about. I would try regreasing the slides and bolts and the sound should diminish!
