Grille delete kit
Old Nov 7, 2007 | 11:36 AM
ernest_210's Avatar
ernest_210
Default Grille delete kit
im about to buy a grille delete kit. does anyone know the difference between the 2 piece than the 3 piece?? thanks
Old Nov 7, 2007 | 11:37 AM
mvr's Avatar
mvr
Default RE: Grille delete kit
buy the 3pc, its a cleaner look.
Old Nov 7, 2007 | 11:49 AM
JT76's Avatar
JT76
3 piece is orig equpt. on the Mach 1 (the one i ordered through American Muscle came in a ford box) the 2 piece looks cheap
Old Nov 7, 2007 | 12:02 PM
BleedinBlue's Avatar
BleedinBlue
I have the 2 piece and have never once been told it looks cheap[&:] You can't even tell unless you know what you are looking for and you get your nose up the grill.
Old Nov 7, 2007 | 12:03 PM
MustangMan00's Avatar
MustangMan00
i got the 2 piece and im fine with it...
Old Nov 7, 2007 | 12:04 PM
JT76's Avatar
JT76
for me, personally,i would rather have the better one... just a pet peeve i guess
Old Nov 7, 2007 | 04:44 PM
LynnBob Mustang's Avatar
LynnBob Mustang
ORIGINAL: stanggang1892
The only difference between the 2 piece and 3 piece is that most cars already come with the third peice in the three piece kit, it is just the part behind the grill and you only need it if it is broken basically. So your wasting your money buying the 3 pc if you don't need it.
I didn't need one on mine as it is fine, so I got the 2 Pc kit and that is all you need.
Lynn
Old Nov 7, 2007 | 04:47 PM
LynnBob Mustang
ORIGINAL: BleedinBlue
I have the 2 piece and have never once been told it looks cheap [&:] You can't even tell unless you know what you are looking for and you get your nose up the grill.
There is nothing to be cheap about, your wasting money on a 3 pc kit if the part ALREADY on your car is fine. If the third pc is broke, then yes you'll need it, otherwise you don't need the 3 pc kit, the 2 pc is fine.
Lynn
Old Nov 7, 2007 | 04:50 PM
LynnBob Mustang
ORIGINAL: LynnBob Mustang
There is nothing to be cheap about, your wasting money on a 3 pc kit unless the part that is ALREADY on your car is broken. If the third pc is broke, then yes you'll need it, otherwise you don't need the 3 pc kit, the 2 pc is fine.
Lynn
Old Nov 7, 2007 | 05:44 PM
2k1gt's Avatar
2k1gt
Its not the same piece. I got the 3 piece kit and the back plastic piece I had to take out is not the same as the one that came in the kit. I have a friend with the 2 piece and think it looks like shi*. Don't be cheap, but the 3 piece.
