engine problems
Old Nov 9, 2007 | 10:29 AM
makbootzy's Avatar
makbootzy
Default engine problems
I traded my eclipse for this 1998 Mustang GT problem is the noise comming from the engine does any know what it is???
http://youtube.com/watch?v=iPEBTp46Hso
Old Nov 9, 2007 | 11:29 AM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
Default RE: engine problems
my first guess would be an exhaust leak.
Old Nov 9, 2007 | 01:33 PM
98SN95's Avatar
98SN95
DEFINITLY LOWER ENGINE PROBLEMS. DOES THE NOISE GET SOFTER AS YOUR TEMP GETS HIGHER, OR DOES IT GET LOUDER?
Old Nov 9, 2007 | 01:54 PM
mustang02racing's Avatar
mustang02racing
lol wow i just had that same exact noise like a week ago thank god for me its and exhaust leak, i thought it was a bent valve or something, i didnt get the exhause leak fixed yet but i see the crack in my h-pipe....try this go on a dirt road or loose gravel, then start the car up and rev the engine and see if u can see the gravel or dust moving around under the pipes or if u got a buddy with a lift then it easy lol good luck
Old Nov 9, 2007 | 02:24 PM
Mark99GT's Avatar
Mark99GT
Could have trimmed the first minuteoff of that video....Thats how my rod bearings sounded when they spun...Get the oil pressure checked, don't go by the "gauge" in the dash. Run low on oil ever?
Old Nov 9, 2007 | 03:30 PM
2002GTAUTOVERT
ORIGINAL: Mark99GT
Ouch
pray for this guy its not a rod bearing. it does seem loud for an exhaust leak.
Old Nov 9, 2007 | 05:03 PM
makbootzy's Avatar
makbootzy
well the car runs fine when it first starts but then when it gets warmed up it starts the noise also I can rev it up at a certain point the noise will stop but at idle the noise is constant...............does anyone know the cost of replacing a rod bearing?
Old Nov 9, 2007 | 05:05 PM
makbootzy's Avatar
makbootzy
oh yeah and the noise does sound low in the engine and in the middle
Old Nov 9, 2007 | 05:30 PM
Mark99GT's Avatar
Mark99GT
Rod bearing replacement requires you to remove the engine and rebuild it. Its not cheap. Mine sounded a lot like yours at first and ended up sounding like this before I fixed it...
http://www.youtube.com/watch?v=pMRPLN3nz_o
Old Nov 9, 2007 | 06:56 PM
makbootzy's Avatar
makbootzy
mine sounds exactly the same
