Need some help, car is sputtering
Old Nov 14, 2007 | 01:53 PM
jojo2003's Avatar
jojo2003
Default Need some help, car is sputtering
I noticed today that when I am in 3rd or a higher gear, and when I push the peddle past about half way, the car sort of sputters for a little bit then goes. And when I shift gears, it will happen again at the same point in the throttle. It just started happening, I am about 1/4 way through the tank I just put in it. I changed the plugs, filter about 3,000 miles ago. Could it just be a bad tank of gas?
Old Nov 14, 2007 | 02:07 PM
gxszone's Avatar
gxszone
Default RE: Need some help, car is sputtering
My '02 autois doing the same thing. I have re-rechecked the spark plugs/COP and the problem temporarily goes away. After going WOT a few times it returns.
Old Nov 14, 2007 | 02:15 PM
Nitti00GT's Avatar
Nitti00GT
That happened to my car a year ago. I checked my plugs and there was oil on 2 of the plugs on my driver's side and also I had a crack in my thermostate housing causing coolant to leak into the front driver's side spark plug well. I replaced the housing and got my seals changed in my head and that took care of the problem for good. So I would recomend checking for leaking coolant and checking your coil packs and your spark plugs.
Old Nov 14, 2007 | 10:14 PM
jojo2003's Avatar
jojo2003
I found out it does it in second gear also. It feels like when you have traction on, and you try to spin alittle on wet pavement, and it cuts out a bit. Well that is what it sort of feels like.
Old Nov 15, 2007 | 12:19 AM
Nitti00GT's Avatar
Nitti00GT
Yeah that's what mine felt like. I had to take the plugs out and dry the oil off and dry oil off of the coil packs and that would fix the problem for like 2-3 weeks. Then it started getting worse and I just had my heads reconditioned with new seals for about 230 bucks but I took the heads off myself.
Old Nov 15, 2007 | 01:20 AM
00blackstang's Avatar
00blackstang
any check engine light?.....could be a bad coil pack...or even a bad ground somewhere
Old Nov 15, 2007 | 02:57 AM
redbullitt's Avatar
redbullitt
i have had coils go out and it was like that. I didnt have a code at first
Old Nov 15, 2007 | 08:23 AM
jojo2003's Avatar
jojo2003
No, I haven't had any extra lights pop up. It drives normal, until I pus the gas further. and once it gets the sputtering out, it will drive normal with my foot down. It just sputters for maybe 10 seconds.
Old Nov 15, 2007 | 08:49 AM
Taeke's Avatar
Taeke
Hi, I have a 2003 GT auto since a few weeks now and noticed the same problem. When accelerating slowly in 3rd or O/D it'll sputter around 1300 rpm. When I cross 1300 rpm when accelerating a little bit faster there's no problem at all. When it starts sputtering I can make it sputtering for ever by sticking to 1300 rpm. The only way to get around is accelerating a bit or decelerating somewhat.
Old Nov 15, 2007 | 10:10 PM
jojo2003's Avatar
jojo2003
This happens no matter what rpm I am at. I put some of that heet in, and filled up the gas to see if that doe anything. I hope it does. Thanks
