PI Swap, where to place second temp sensor on intake HELP ASAP
So where can I place the second temperature sensor. Or can I just splice the wires and attached both sensor wires to the one sensor?
RE: PI Swap, where to place second temp sensor on intake HELP ASAP
one of them is the sending unit for your gauge and the other is for the computer i believe. if theres only one port on the intake manifold go to the autoparts store and get a t.
tap the flat spot. 3/8-18 npt i believe it what it takes.. or you can always buy a T if you want to do it that way.
My heads have a sensor on the inside of the driver side head that i just plugged into. That is another option if you don't feel like taping it or buying a new cross over.
It is a 3/8 pipe thread. I just did a complete PI swap and found this out the hard way. there should be a spot that looks like it would hold another sensor left of the thermostat.
There is a spot on the back of your block. Thats where i put mine. it is 3/8 pipe thread to. I pulled the wire from the harness and put it back there.
No, you can't splice into the other sensor, they have different values.
