good idea
Old Nov 24, 2007 | 11:22 PM
bigjbuff28's Avatar
bigjbuff28
Default good idea
i was thinking about getting a fox but i like the looks of the sn95 better... i am looking at getting a 96-98 gt and this was my idea
-shorty headers $300
-cat back $400
-cai $100
-373's ($400 installed)
-lightened flywheel $400
-24#'s injectors $200
-70mm throttlebody $200
+ car $5000
=$7000
is there anything that im not thinking about assuming the brakes and the tires are fine and nothing needed to be replaced? and do you think i could be around 240RWHP
Old Nov 24, 2007 | 11:31 PM
OldSkool's Avatar
OldSkool
Default RE: good idea
i wouldn't worry too much about the shorty headers or the flywheel. i know it's rotational mass, but IMO 400 just isn't really worth it. Take that money and get a really good tune, you'll notice a lot more gains that way, especially after you get the other bolt ons you listed. everything else sounds pretty good, except for most people will tell you to go with 4.10 gears, unless you plan on putting a lot of power down later, or your tires suck or some other factor you haven't mentioned here.
The rest of the mods sound ok, but you won't be at 240. You're probably putting down about 195 ish stock, and there is no way that those mods will give you 40+ rwhp. you might have like 220 or something. IMO save your money
Old Nov 24, 2007 | 11:42 PM
bigjbuff28's Avatar
bigjbuff28
well i dont mean at all to question your knowledge but why would i forget about the shorty headers when ive been told that is an easy 5-8 hp and how much hp can i get from a good tune?
Old Nov 24, 2007 | 11:48 PM
OldSkool's Avatar
OldSkool
shorty headers will not get you 5-8 RWHP. they might get you that at the crankshaft on a good day. a good tune can get you over 10 hp at the wheels
Old Nov 25, 2007 | 12:16 AM
96_LAstang's Avatar
96_LAstang
ORIGINAL: bigjbuff28
-cat back $400
-cai $100
+ car $5000
=$7000
Sounds like a start but think about a PI swap also
Old Nov 25, 2007 | 12:32 AM
bigjbuff28's Avatar
bigjbuff28
well i knew not 5-8 at the wheels... i always hear about a PI swap but dont know what it is
Old Nov 25, 2007 | 12:48 AM
mustangman36578's Avatar
mustangman36578
a pi swap is switching the non PI heads that came on the 96-98 GT to the PI (Performance Improved) heads that came on the 99-04 GT. they flow a lot better and give you more horsepower.
Old Nov 25, 2007 | 12:56 AM
bigjbuff28's Avatar
bigjbuff28
isnt that quite a bit of work to switch out heads??? i saw something on a PI intake that doesnt look to hard.. how much hp do you think i could get from the heads swap or the intake swap
Old Nov 25, 2007 | 01:06 AM
Sxynerd's Avatar
Sxynerd
Your plan looks good wrote out, but I believe the practical aplication will be something else.
Old Nov 25, 2007 | 10:03 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
My NPI put down 188 rwhp with a mid pipe, cat back, intake, and a 70mm throttle body. The NPI's are slow as $hit. Save your money and do the PI swap. It consists of changing the heads, cams, and intake manifold. If you want to save some money then just do PI cams and the intake manifold. Each can be had for about $100 a piece. If you get Romeo PI cams the install is so much easier. You can swap the cams and intake manifold in about 5 hours if it's your first time. You'll usually get about 45 rwhp with cams and intake manifold swap and a tune.
