getting over 150 mph
Old Mar 10, 2005 | 11:36 PM
04GTPony's Avatar
04GTPony
Default getting over 150 mph
what exactly makes or lets a car go behond what the speedomotor says? gears? computer crap? any ideas or thoughts? some basic steps for a high top speed? thanks guys.
Old Mar 10, 2005 | 11:40 PM
LIVIN_LEGEND's Avatar
LIVIN_LEGEND
Default RE: getting over 150 mph
3 oclock in the morning on a highway with no one around and a chip or programmer to take the speed limitor off...........besides the way, don't do it
Old Mar 10, 2005 | 11:46 PM
Aixtreme89's Avatar
Aixtreme89
It depends on the final gear in your transmission and the gear in your rear end, and the diameter of your tires. Lower your gear ratio in your rear end, you will get a higher top end. But lag at low speeds. Also the same principal for the gears in your transmission.
Old Mar 10, 2005 | 11:49 PM
dan's Avatar
dan
actually, believe it or not most people get to top speed in 4th gear instead of 5th simply because 5th doesn't have quite enough torque, so gearing up (numerically down) may actually harm top speed. I may be wrong though
Old Mar 10, 2005 | 11:51 PM
Aixtreme89's Avatar
Aixtreme89
If you know the RPM, the gear ratio and the tire diameter, you can figure the vehicle speed, or mph, by using the following formula:
MPH= (RPM x Tire Diameter) / (Rear End Gear Ratio x 336)
To Figure out the gear ratio needed for a certain speed:
Gear Ratio= (RPM x Tire Diameter) / (MPH x 336)
Old Mar 10, 2005 | 11:54 PM
Aixtreme89's Avatar
Aixtreme89
Heres the formula for RPM:
RPM= (MPH x transmission ratio x rear end gear ratio x 336) / (tire diameter)
Old Mar 11, 2005 | 12:01 AM
blueangelfightr's Avatar
blueangelfightr
Why do you wanna go over 150 mph. I doubt you can handle it. 130 stops it for me.
Old Mar 11, 2005 | 01:20 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Ive done 155+ using my fifth gear. 4.10's and drag radials. LOL
Old Mar 11, 2005 | 02:17 AM
Emann0007's Avatar
Emann0007
155??? with 4.10's.. Didn't know that was possible. I got mine to 136... prolly woulda gone a few more mph but i stopped, the vert top was fluttering like crazy and I thought it might fly away without me.
Old Mar 11, 2005 | 04:08 AM
Phillyblunt474's Avatar
Phillyblunt474
yea stangs arent really built for the high speeds, kinda scarey really i got to about 145 and decided i was done casue you can feel everything gettin lighter. Your a grease spot on the road if anything goes worong at those speeds.
