Help with Trac-lock diff?
Old Mar 11, 2005 | 04:16 PM
merfsiu's Avatar
merfsiu
Default Help with Trac-lock diff?
When i first got my mach, if i would drop the clutch coming out of a turn, both tires would spin and it would fishtail nice and smooth. but now, it seems as if only one tire spins and the other will hook then spin and the other will hook. This can get real jerky. Last time i took my mach in for warranty work, i asked them to check out the diff and they said it was within spec. If i dump the clutch going striaght both tires spin and things seem normal. So i am thinking that something is wrong with the trac lock. I dont think ford is going to help me out on this.
Has anyone else had this problem?
Would it be hard to inspect myself?
What tools and supplies would i need?
What should i look for?
Old Mar 11, 2005 | 09:29 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Default RE: Help with Trac-lock diff?
Ok, the clutch packs in the rear end of Mustangs have to be adjusted all the time! You can make them tighter with different shims. Seems to me like they are getting loose and not catching as good as they used to. Its not anytihng you want to mess with. Also i would put a bottle of adative in the rear end. Might not have been put in at factory.
Old Mar 12, 2005 | 12:02 AM
Tims 88GT's Avatar
Tims 88GT
get a locker that will sove your problem
scenicnights
Feb 3, 2016 09:43 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
Cavedawg
Sep 17, 2015 09:51 AM
Sep 1, 2015 08:16 PM
92 5.0stang
Aug 13, 2015 06:46 AM
