4.6l compression ratio
Old 12-12-2007, 03:08 PM
stangiac03
stangiac03's Avatar
Default 4.6l compression ratio
has anyone ever put NPI or PI heads on a 99 cobra block? or just used the 4.54 dished pistons with the NPI or PI heads? would the compression ratio be to high for pump gas and cause detonation?
stangiac03 is offline
Old 12-12-2007, 03:40 PM
oxfordgt
oxfordgt's Avatar
Default RE: 4.6l compression ratio
The compression ratio would be 9.8:1 with NON-PI heads and 10.7:1 with PI heads. With Non-PI heads you will be fine on pump gas but with PI you will have to run 93 octane and pull timing out.
oxfordgt is offline
Old 12-12-2007, 05:12 PM
stangiac03
stangiac03's Avatar
thanks. are you sure on this cause i have asked numerous people and i have gotten so many diffrent answers one guy told me 11.3:1 on NPI heads. lol.
Old 12-12-2007, 05:17 PM
contentsunderpressur
contentsunderpressur's Avatar
ORIGINAL: stangiac03
Yes, oxford knows his ****.
contentsunderpressur is offline
Old 12-12-2007, 05:36 PM
Sxynerd
Sxynerd's Avatar
Im not smart so I could be wrong. But wouldn't the CR drop?
Sxynerd is offline
Old 12-12-2007, 07:09 PM
Nitti00GT
Nitti00GT's Avatar
ORIGINAL: contentsunderpressur
+1 Ox def knows what he is talking about.
11.3:1 sounds high and from what I have been told you will have to run race fuel.
Nitti00GT is offline
Old 12-12-2007, 08:48 PM
oxfordgt
oxfordgt's Avatar
Yes I'm sure. If you were to run flattop pistons with PI heads you would get 11.2:1 CR which means if you wanted 11.3:1 with non pi heads you would have to use domed pistons with about a 2cc dome. LOL have fun running that on the street.
oxfordgt is offline
Old 12-12-2007, 08:59 PM
Mark99GT
Mark99GT's Avatar
What is the piston dish on the 99 cobra?
Mark99GT is offline
Old 12-12-2007, 09:05 PM
oxfordgt
oxfordgt's Avatar
4.54
oxfordgt is offline
Old 12-12-2007, 09:15 PM
Mark99GT
Mark99GT's Avatar
So what numbers are you using to calculate the CR then?
Ive got:
Bore: 3.552"
Stroke: 3.543"
Piston Dish: 4.54cc (I read somewhere else they were 3cc)
Head G Bore: 3.625"
HG comp thickness: .03"
Deck height: .012"
CC volume: 51cc (I also read these were 49.77cc)
I'm getting a CR of 10.2:1 with the NPI heads and 11.5:1 with the PI heads. What numbers do you use?
Mark99GT is offline
Quick Reply: 4.6l compression ratio
