Loud knocking sound from drivers head
Old Dec 22, 2007 | 10:54 PM
Dingo0079's Avatar
Dingo0079
Default Loud knocking sound from drivers head
Happened at redline pretty much instananeously, car is still making power I even drove it 20 miles to get it home any ideas on what it could be, other than the noise it still runs great, no smoking idles fine makes power.
Car is a 2001 with about 75000 miles onit 10,000 with the kenne bell, any suggestions would be appreciated.
Old Dec 22, 2007 | 11:05 PM
97targa's Avatar
97targa
Default RE: Loud knocking sound from drivers head
Bummer man. Is the sound really loud like a rod knock or your sure it's from the head? I'm sure you put your mechanics ear up to it so I'll go from there. At redline with a supercharger the aluminum heads get a kick in the pants because of the vast amount of heat that is produced. My guess is you burned up a guide. If the noise isn't super lud and more so annoying, I would try to throw some Slick 50 in there and maybe that will quite it down and coat the surface long enough for you to save up a few bucks to get a fresh set of heads on there. Honestly, I wouldn't run a supercharger without the best intercooler available and also step tube headers. I know Kooks are a mouthful to swallow as far as expense, but they are wll worth it. They have larger primaries to rid the heat away from the head as soon as possible to avoid these instances. Ohh, LT's is a must, do you have shorties? Stockers are the worst!
Old Dec 22, 2007 | 11:50 PM
Dingo0079's Avatar
Dingo0079
yeah stock manifolds, it is intercooled, noise is definately from thw head, if it reqiures removal then I guess I willjust have to get my next big mod Livernois built motor.
Old Dec 23, 2007 | 09:56 AM
kenv's Avatar
kenv
The title of this thread had me going for a moment. I was thinking-- Too much tequila?
Old Dec 23, 2007 | 10:29 AM
contentsunderpressur's Avatar
Does it only make the noise at redline or once it started it kept making it even at an idle?
Old Dec 23, 2007 | 11:42 AM
Dingo0079's Avatar
Dingo0079
idle to redline does not change in volume only in frequency with the rpm, I was thinking broken valve spring.
Old Dec 23, 2007 | 12:02 PM
Yea, it could be. Pull the vavle cover and see what's doing it. I was thinking for a min it could be detonation but if it kept doing it afterward then something has come loose in there. You said it didn't hurt the performance though so I'm not sure if it would be a valve spring or not. It should have lost some power if a spring went.
Old Dec 24, 2007 | 03:51 PM
Dingo0079's Avatar
Dingo0079
I only gassed it once after it happened car isover 400rwhp so even dropping a cylinder if it did it still lit up the tires when I hit it, I will have to check it out after the christmas break, and let you know what I find, I hope I can fix it soon it will suck if I have to wait for the built motor, to much down time but if I have to do it it is going to be done right.
Old Dec 24, 2007 | 05:19 PM
iamyourdaddy26's Avatar
iamyourdaddy26
yeh mine mad the same noise but i blew a main bearing. so check that out.
Nick Oliver
Oct 17, 2018 04:22 AM
2007StangV6
Jan 28, 2016 06:09 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 04:12 PM
