Head and Cam Switch?
Old Jan 16, 2008 | 08:44 PM
1997Stang's Avatar
1997Stang
Default Head and Cam Switch?
I am putting in pi heads and cams on my 97 gt. I need a new intake manifold right? Also if i buy a new intake manifold will that bolt right to the other stock parts or will i need to get more stuff for the original stock parts to bolt up to it?
Old Jan 16, 2008 | 08:53 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
Default RE: Head and Cam Switch?
If you're buying PI heads, get a PI intake.
Old Jan 16, 2008 | 08:56 PM
1997Stang's Avatar
1997Stang
I was looking at a PI intake manifold from rpmoutlet and then i just read a forum right before i posted this about how bad rpmoutlet is. By PI intake do you just mean intake manifold?
Old Jan 16, 2008 | 09:35 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
Yeah, intake manifold. They're for sale all over from $150 - $200.
Old Jan 16, 2008 | 10:46 PM
cp51's Avatar
cp51
ya, ull need a PI intake cause 97 manifold ports wont line up. but everything else should line up. i believe itll boost ur compression ratio though. so if ur thinking of going sc in the future watch out for that.
Old Jan 17, 2008 | 08:29 AM
1997Stang's Avatar
1997Stang
Is their any way that i can get the compression down cause i do want to get a supercharger in the future. Also before i do the PI swap i was going to get a 4.6 stroker kit cause my internals are going bad.
Old Jan 17, 2008 | 09:06 AM
Blown98SN95's Avatar
Blown98SN95
What I did is found a 2002 GT motor for 1200 bucks with 20000 miles dropped it in and gained a good bit of horsepower. Later on I replaced the "pi" with the Typhoon intake. And yes RPMoutlet sucks. Just some thoughts.
Old Jan 17, 2008 | 10:37 AM
10inch Terror's Avatar
10inch Terror
If you are changing the pistons, then you can change the compression ratio to something blower friendly when you buy the stroker kit. If you are doing a stroker go the Manley 23cc or the Manley 28cc for a 2V blower motor. I'd lean towards the 23cc to get you around a 9.2:1 compression ratio. The 28cc puts it a little too low @ 8.75:1.
Old Jan 17, 2008 | 11:08 AM
cp51's Avatar
cp51
if u get the lower compression ratio itll handle the boost better, and u can put more in... also u want a high revving motor if u go with a centri sc(vortec...) not a KB. Cause they only make their boost in the high rpm range. so if u stroke it, itll be difficult to get the high rpms... but i mean... it depends how much u do...
Old Jan 17, 2008 | 12:05 PM
10inch Terror
ORIGINAL: cp51
I personally like to add stroke to those motors. It helps with the "soft" bottom end when off boost. RPM is not a concern. My turbo mod motor spun to 9000+ and my brothers record-holding N/A mod motor saw 11,000 on the dyno. All with the same stroker crank.
