different ? about my 75mm tb
Old Jan 21, 2008 | 12:28 AM
sleeping stallion's Avatar
sleeping stallion
Default different ? about my 75mm tb
ok as some of u may no and have helped me already my tb is messing around with my car.
but now this is the problem i have a auto, so when it is going from 2 to 3 or 1 to 2 it seems like it slips into neutral for a seconds or so then it grabs gear. has anyone ever experienced it.
my second ? since im idleing a bit higher does that make me run lean or rich i was told by 2 ppl already i will run lean.
one person said the only way to fix that is to actually dyno tune it.
any help please guys i have searched and searched but no one really says what the final thing is
Old Jan 21, 2008 | 02:07 AM
H0SS302's Avatar
H0SS302
Default RE: different ? about my 75mm tb
your idle shouldnt be higher at all... turn it down with the screw
Old Jan 21, 2008 | 02:45 AM
sleeping stallion
i dont have that screw its a 75 mm bbk i dont see it anywhere
Old Jan 21, 2008 | 05:16 PM
sleeping stallion
bump
Old Jan 21, 2008 | 06:09 PM
rmr1923's Avatar
rmr1923
there should be an idle adjustment screw on the throttle body. look at the throttle body and find where the throttle cable is hooked up. play around with it and see how it rotates to open and close. when you close it, the adjustment screw should be what stops it from closing further. you should just be able to get a screw driver and adjust the idle without any kind of tuning.
Old Jan 21, 2008 | 06:22 PM
sleeping stallion
u mean where it stops there is a screw but not the idle screw that everyone says
Old Jan 22, 2008 | 12:08 AM
rmr1923's Avatar
rmr1923
here's a picture of my throttle body ('02 GT). this is a 75mm BBK, so it should be the exact same throttle body that you have. this is the screw that you can use to adjust your idle.
Old Jan 22, 2008 | 12:28 AM
ZW99GT's Avatar
ZW99GT
That will adjust you idle, if the blade is open, and letting air in. I had this problem on my other 99 GT. I did the IAC mod, and it helped a little. The only real way to "change" the idle RPM is with a tuner.
Old Jan 22, 2008 | 07:50 PM
sleeping stallion
oh ok yea i got the same one i thought the srew that was on the side. i played with that one for awhile but then the pedal is sticky.
and as for adjusting it with my diablo tuner how would i do that and where should i set it
Old Jan 23, 2008 | 12:11 PM
sleeping stallion
come on guys i no im not the only person that this has heppen to
