Radio Problem
Old Jan 22, 2008 | 09:24 PM
dougs97mustang's Avatar
dougs97mustang
Default Radio Problem
1998 mustang gt has the stock mock 460 system in it the radio comes on and plays music really quiet. you have to get right on the speaker to hear it. any ideas? I already replaced the back two amps.
Help would be great thanks.
Old Jan 22, 2008 | 10:10 PM
onesickstang01's Avatar
onesickstang01
Default RE: Radio Problem
are you sure amp connections are good? also do you have a mute/silence mode on the headunit? make sure all the wires are tight on the back of the unit or any other connection you see.
Old Jan 22, 2008 | 10:20 PM
dougs97mustang
I will check. I have just put a new aftermarket one in and had the same problem. thanks
O are there any other amps or anything that could have gotten wet I have reason to beleive that it is a flood car the radio has not worked right since i got the car
Old Jan 23, 2008 | 09:17 AM
nebiag's Avatar
nebiag
The only amps are in the back of the trunk right under the rear speakers. There should be two small ones. And if they got wet your car would have been under some serious water. What types of amps did you replace the stock ones with.
Old Jan 23, 2008 | 11:30 AM
dougs97mustang
I got some stock replacments for it. They were exactly like the old ones I could not find any wires loose around the headunit.
Old Feb 1, 2008 | 06:44 PM
dougs97mustang
still no luck????
Old Feb 1, 2008 | 08:23 PM
4.698GT's Avatar
4.698GT
Dumb question but did you check the bass and treble settings on the radio?
Old Feb 1, 2008 | 09:11 PM
Ecstasy's Avatar
Ecstasy
wonder if he got the proper installation the adapter for hte amps on the mach 460 system if not, thats probably your problem.
Old Feb 2, 2008 | 02:57 AM
JayDs Ibanez's Avatar
JayDs Ibanez
check the connections in the back, i had my mustang wired straight to an aftermarket unit and it was so weak, i rewired it to the amps and put the stock unit on
Old Feb 2, 2008 | 03:20 AM
MollyMustang's Avatar
MollyMustang
I am assuming that you are talking about your factory head-unit, not aftermarket? If your Mach 460 is like mine in my 2000 GT you should actually have three amps. The two in the rear only power the rear speakers. The third amp is in the head unit and it powers the front speakers and may also possibly feed signals to the rear amps. Hope this helps.
