Aluminum flywheel or not?
Old 01-28-2008, 05:20 PM
jh2586
jh2586's Avatar
Default Aluminum flywheel or not?
Hey guys i have a 2001 and a half GT. i messed up my tranny about a month ago.. (broke the syncros) and it wont shift into 2nd gear.. now it's at a tranny shop and they're offering me to change my clutch and flywheel since they are worn. i've already said ok to the clutch im getting a stage 2 clutch put on there.. but my question is.. should i get an aluminum flywheel? or should i just get a new steel one?
jh2586 is offline
Old 01-28-2008, 05:31 PM
DRKSIDE_GT
DRKSIDE_GT's Avatar
Default RE: Aluminum flywheel or not?
Just make sure you put it in good hands. Just a few months ago my friend ordered an aluminum flywheel and spec clutch. Another friend of his, an employee of pep boys, did the install. It lasted somewhere around a month. That pretty aluminum flywheel is now only good for recycling.
DRKSIDE_GT is offline
Old 01-28-2008, 05:32 PM
MU71L4710N
MU71L4710N's Avatar
just get the stocker resurfaced...dont buy another steel one unless yours is unusable now. aluminum...meh thats up to you. you can search and find arguements for and against it all day long.
MU71L4710N is offline
Old 01-28-2008, 05:59 PM
StylinM6s
StylinM6s's Avatar
I'd go with aluminium if you were there 2 switch around. Less drivetrain loss, rev faster
StylinM6s is offline
Old 01-28-2008, 08:12 PM
Ehmark
Ehmark's Avatar
I love my fidanza flywheel. I got the flywheel and my clutch for under 500 on ebay check it out.
Ehmark is offline
Old 01-28-2008, 10:05 PM
GhostRider02GT
GhostRider02GT's Avatar
depends on if you wanna drag or road coarse. If you wanna drag, if your stocker has no cracks or warpage, get it resurfaced, or replace it with a new one. The heavier flywheel has more inertia and momentum, ergo when its spinning at 4500 RPMS and you dump the clutch, it doesnt slow the motor down as per say an aluminum flywheel which has less rotational energy. The aluminum will help in the road coarses b/c your not launching as much and you need the quicker revs of the lighter flywheel.
GhostRider02GT is offline
Old 01-28-2008, 10:11 PM
Ecstasy
Ecstasy's Avatar
get the ford racing steel one, i wouldnt go aluminum, ive seen over time the aluminum ones screw up or hurt you because of it being lighter.
Ecstasy is offline
Old 01-29-2008, 09:38 AM
GolfmanSpeck
GolfmanSpeck's Avatar
ORIGINAL: GhostRider02GT
^^ Best answer to this question I have ever seen!
GolfmanSpeck is offline
Old 01-29-2008, 12:48 PM
Dsmfighter
Dsmfighter's Avatar
Damn ghost...you beat me to it. Good explanation too.
Dsmfighter is offline
Old 01-29-2008, 07:24 PM
GhostRider02GT
thats how my shop and physics teacher explained it to me
Quick Reply: Aluminum flywheel or not?
