setting keyless entry
Old Feb 1, 2008 | 09:39 PM
04 mustang's Avatar
04 mustang
Default setting keyless entry
does any one know how to reset the keyless entry or the factory codes to reset
Old Feb 1, 2008 | 09:42 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: setting keyless entry
what is the problem you are having exactly?
Old Feb 1, 2008 | 09:44 PM
04 mustang's Avatar
04 mustang
i bought a used one and the the toyota dealer i bought it from could not tell me how to reset the keyless entry
Old Feb 1, 2008 | 09:50 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Ok, I'm confused. Toyota dealer?
Old Feb 2, 2008 | 01:36 AM
tim2002gt's Avatar
tim2002gt
I'm going to assume you have a 2004 mustang. First, put the key in the ignition. Turn it on and off 8 times, leaving it in the on position on the 8th turn. Then push the lock button on the remote/remotes that you want to program. The locks will cycle automatically. Turn the key to the off position, wait about 30 seconds and the locks should cycle one more time. Then take the key out and try the remotes. If it doesn't work, try it again.
Edit: I re-read your original post and now I'm confused too! The above info may not be what you are wanting. That is how you program the keyless remotes.
Old Feb 2, 2008 | 09:04 AM
03GTJC's Avatar
03GTJC
ORIGINAL: tim2002gt
Wow, my keyless entry hasn't been working these last few months. Not a big deal, it never really bothered me. I thought it was a trip to the dealership kind of problem. But I went ahead and did the 8 turn trick and it worked like a charm! Thanks so much!
Old Feb 2, 2008 | 10:06 AM
Blacksslumina's Avatar
Blacksslumina
This technique also works with aftermarket alarms and remotes on ford vehics. ie. viper
Old Feb 2, 2008 | 05:31 PM
tim2002gt's Avatar
tim2002gt
ORIGINAL: 03GTJC
ORIGINAL: tim2002gt
Glad I could help![8D]
Old Feb 4, 2008 | 09:43 PM
04 mustang's Avatar
04 mustang
Default RE: setting keyless entry key pad
i bought a used mustang that has a keyless entry key pad on the door and i need the factory code to reset the personal code.
Old Feb 4, 2008 | 10:16 PM
califas_1987's Avatar
califas_1987
Never seen a stang w/ a number pad on the door... but my thunderbird had one and it had the factory code on the door jamb, and on one of the hinges in the trunk. Should be 5 digits.
But on a stang?? Oh well, its a ford.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
