Stalling Problems
Old Feb 6, 2008 | 10:06 PM
20StangGT00's Avatar
20StangGT00
Default Stalling Problems
I recently installed my new 75mm throttle body, upper plenum, and exhaust components on my 2000 GT and sometimes it stalls out when the rpms drop down. I checked the intake for leaks and could not find anything wrong. I then installed the performance tune from the Diablo Predator and that seemed to make the car run better but now its back to the same problem. I dont know what is wrong. I was thinking that if I were to get a custom tune for my modifications it would help the problem but i dont know. Anyone familar with stalling problems?
Old Feb 6, 2008 | 10:50 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default RE: Stalling Problems
IAC is my guess
Old Feb 6, 2008 | 10:53 PM
AmericanRicer87's Avatar
AmericanRicer87
ORIGINAL: 99BlackPonyGT
IAC is my guess
+1
Old Feb 7, 2008 | 01:10 PM
mestit3's Avatar
mestit3
+1
Old Feb 7, 2008 | 02:27 PM
stangdriver2007's Avatar
stangdriver2007
IAC and dont bother cleaning it like everyone says cuz it will only last for a little bit. Id just go by a new one they are50 bucks
Old Feb 7, 2008 | 02:33 PM
20StangGT00
Thanks for the help, i'll get a new one on there tommorow and let you know how it works out.
Old Feb 7, 2008 | 03:25 PM
techsent's Avatar
techsent
surprisingly, it may be your air filter. Mine was stalling every other 2 or 3 stop lights. it's a cone type I so washed it thoroughly, let it dry and no problems since.
Old Feb 7, 2008 | 08:45 PM
20StangGT00
Well i recently installed my CAI kit which came a new filter and that was less than 300 miles ago so it couldnt be that. The stalling problem didn't start until i installed the TB and plenum.
Old Feb 7, 2008 | 09:17 PM
dtkikols's Avatar
dtkikols
ORIGINAL: 20StangGT00
if it didnt start until after you installed your TB id go back and make sure everyting is tight and nothing was forgotten to be put back on. also check your TPS.
Old Feb 7, 2008 | 09:33 PM
AvidMustang's Avatar
AvidMustang
Would the IAC throw any codes or would it just idle funny? I have a similar problem but my cousin who has like a 4k tuner checked the IAC and didnt see anything wrong.
