Some questions after a tragic story....
Old Feb 9, 2008 | 04:21 PM
dlazrael's Avatar
dlazrael
Default Some questions after a tragic story....
Well on 9/11/07, I was the victim of a hit and run accident. Left me with a strained lower lumbar back and a partially herniated disk. Well I am all better now (thank god for chriopractors, physical therapy and the healing powers of the human body). BUT my baby... she's done for. I was (essentially) PIT'd into a guardrail at 43 mph (so the accident ppl said), and the impact was on the left front of the fascia. the car then proceded to slide down the guardrail and rip the fascia off, was well as doing all this, the impact and uni-body construction twisted the frame. The crash impact bar however, did it's job, and even the radiator was still in one piece. The hood was ripped off from the fender lock(ruined the hood) and the mounting bracket for the radiator was bent pretty bad. All this aside, the car was considered a total loss by $100. (no kidding, it was $100 over the total loss limit). So I got the car back a few days ago (salvage title for the win!) and I've decided since mechanically, everything is fine except the frame - I'm going to purchase a old worn out v6 that was NOT wrecked and change EVERYTHING (motor, trans, axles, suspension parts, interior, rear end, exhaust, dash, wiring, you name it.)
So, the main points of this post:
What am I going to encounter, other than some obvious needs for welded brackets (i.e. exhaust runners) and some new sub-frames, and possible a new K-Member (if its bent). What ELSE am I looking at.
I am going to change out my wiring harness, and the entire engine bay and driveline. All the suspension componants (shocks struts, axles, A-arms, and the entire steering rack assy), internal dash will swap (I will need a tech to exchange the airbags however), seats, carpeting, and all that.
I know I will not be able to put my mach 1 shaker back on, due to the hood NOT having a hole in it, but thats ok for now - makes it more like a sleeper
Another question is intake to hood clearance, will I run into issues?
Lastly - Badging - would it be bad to rebadge this car?
Thanks in advance
Old Feb 14, 2008 | 12:37 PM
99mustang38or46's Avatar
99mustang38or46
Default RE: Some questions after a tragic story....
Hey man I did this same swap a year ago all I needed was of course the engine and tranny, wiring harness, computer, hydr. brake assy.and driveshaft, also need to have and H or X pipe and exhaust. I also needed the steering wheel and pedal assy. because I went from an auto to a manual. after all is said and done get a dealer reflash and you will be good to go. Cost my about 1000 bucks and 3 months worth of free time. Anything else hit me up!
Old Feb 14, 2008 | 01:10 PM
Sxynerd's Avatar
Sxynerd
Rebaged it of course.... GT performace with v6 insurance!
Old Feb 14, 2008 | 01:16 PM
Brute03's Avatar
Brute03
man that sucks bad, goodto see you back though. the whole swap seems like a ton of work if you ask me but if you can do it yourself, go for it. as for badges, i would shave 'em all off [8D]
Old Feb 14, 2008 | 01:55 PM
jmac72187's Avatar
jmac72187
corner carver
The only badge you really have to worry about not being "right" would be your rear Mach badge. The fender emblems are the same on sixxers as they are on 03 Machs. Just replace the rear emblem with something like 281 or something. I wouldn't put Mach on there or anything. Use some sort of badge that makes it look different than a v6 though.
Old Feb 15, 2008 | 04:39 AM
JayDs Ibanez's Avatar
JayDs Ibanez
glad to hear you're okay, car will be alright
Old Feb 15, 2008 | 06:35 AM
DTK's Avatar
DTK
Glad to hear you are ok.
You could easily do a swap like that with what parts you have from the buy back.
Personally, I would think that going from a Mach to anything lesser wouldn't be too satisfying.
There is nothing wrong with a GT (I have one) or a V6 but you were driving around in a realMach.
You can make a V6 donor car look likeanything but it still will be a clone and there is nothing wrong with that either as far as I am concerned but I would at least want nothing less than what I had........................just my thoughts.
You got your insurance payout right? Take that money + sell whatever parts you can from the carcass and either buy another Mach or hell get a terminator.
Anyway, if you do a swap let us know and show pictures of the project. It would be a fun project.Good Luck!
Old Feb 15, 2008 | 07:32 AM
2000GT4.6's Avatar
2000GT4.6
He has all the parts... I see no reason for him to buy another mach 1 when he can have one at a V6 price. Probably will come out ahead on the insurance money... time for a FI 4v
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
