Best Traction Solution
Ok first off I am very fimiliar with Mustang's in general. But I want to go with something that has been proven to work. I tell you what I was thinking and then you guys can throw in your suggestions.
GEAR: 3.73
AXELS:MOSER
WHEELS:10.5
TIRES FOR STREET/STRIP
RAG RADIALS, MAYBE M&H OR NITTO OR MICKEY THOMPSON
SPRINGS:H&R OR EIBACH
UPPER+LOWER CONTROL ARMS: STEEDA OR M&M
ALUMINUM FLYWHEEL:SPEC
LIMITED SLIP DIFF OR LOCKER:MOSER
Am I missing anything? My stock suspension is killing my 60ft times. What do you guys suggest? My main mods are listed below. This is my d&d btw. I dont want anything over the top, I save that for my drag car.
GEAR: 3.73
AXELS:MOSER
WHEELS:10.5
RAG RADIALS, MAYBE M&H OR NITTO OR MICKEY THOMPSONSPRINGS:H&R OR EIBACH
if you are looking for drag racing I wouldn't go with either spring unless you are looking at the drag launch springs. Double adjustable uppers would help, welded tq boxes and axle tubes as well!!
Thanks guys for your suggestions. I think I am going to go with a good set of lowers with spherical bearings, Yukon 31 splines and LSD, and MT slickson a set of welds. What can fit under stock fenders...15x10, I would guess would be best. Do you guys think with this setup I will be able to launch hard and stick to the track, without anything more.
Sep 8, 2015 11:50 AM
