WHAT WEIGHT DIFF FLUID?
Old Feb 28, 2008 | 02:31 PM
03greyGT's Avatar
03greyGT
Default WHAT WEIGHT DIFF FLUID?
Ok, so after doin a search on the forum, ive been seeing mixed opinions about what weight diff fluid to use. Im going with RP and have heard people using 75W90 as well as 75W140...is there any one thats particularly better or recommended? Thanks guys
Old Feb 28, 2008 | 05:33 PM
Obsequious1's Avatar
Obsequious1
Default RE: WHAT WEIGHT DIFF FLUID?
I know that 7.5 inch rears take 80w-90 and 8.8 rears take 75w-140,
Old Feb 28, 2008 | 06:14 PM
03greyGT's Avatar
03greyGT
ok, thanks, Ive been doing a ton of looking and it seems that the majority of people say ford recommends 75W140 for the 8.8s with limited slip...
Old Feb 28, 2008 | 06:32 PM
Obsequious1
Yea, I guess the used the 7.5 rears in the V6's.
Old Feb 28, 2008 | 07:08 PM
03greyGT's Avatar
03greyGT
yeah the sixers have the 7.5...same with the 4 banger and 3.0 2wd rangers
Old Feb 28, 2008 | 11:07 PM
ottos's Avatar
ottos
The manual says 75W140 and dont' forget 4 oz of friction modifier.
Old Feb 29, 2008 | 10:18 AM
Brute03's Avatar
Brute03
remember, if you're going to use RP, you don't have to add any friction modifier
Old Feb 29, 2008 | 03:42 PM
mach1ford's Avatar
mach1ford
is rp really better?
Old Feb 29, 2008 | 04:22 PM
03greyGT's Avatar
03greyGT
I bought friction modifier cause i have a built rear end and I have more clutches in the carrier making it pretty tight...so i bought the FM for safe measure
Old Feb 29, 2008 | 05:01 PM
Jbauer's Avatar
Jbauer
You don't NEED mdifier if you run redline or RP, but i would recomend it..it won't hurt at all, RP and RL told me to go ahead and add it if i was worried, and i knew they probably didnt have enough for the lsd
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:42 PM
